Tesla Patent 382282, and all related to his transformers/converters
Started by clone477, February 07, 2009, 04:31:11 PM
Room3327
Thanks robbie,
   All week I have wanted to post a screen shot of a properly tuned output.  This is a shot of the two 90 degree out of phase sine waves adjusted for minimum distortion, maximum voltage, and 90 degree phase difference.  This is the actual signals feeding my field coils, I am using series resonance and it is running at 2.6 KHz.  The scale is 20 volts per division.
I should probably add I am using a .33 uf capacitor in series with the audio output and it resonates at 2.6 KHz with my coil design.  2 uf caps made it resonate at 1 KHz.  By changing capacitor value you can make it resonate at any frequency you want.  In series watch and tune for voltage maximum at the resonate frequency.  This arrangement gave me almost 60 volts Peak to Peak across my coils from a 17 volt DC input at resonance with only 275 ma. current.
TheNOP
@Room3327
if it ever happen again, please try to see if it is upload, download or a process that is jammed.
pm me the IP, i will try to get infos about it.
with so many advertising on this forum, i would not be suprise if it was one of them scripts that is causing you problems.
set IE internet zone on high security
set the trusted zone on medium or medium high
and add the sites you want to fully work to the list.
this way you are using the trusted zone list as if they were simple internet half trusted sites.
all the other, not listed sites, will not be allowed to run scripts on your puter.
this shield you out from most of offsite advertising.
amigo
What advertising on the forum?  Are you telling me you people are not running FF Adblock+ extension? :)
Sheesh...I don't see any ads unless they are images hard coded into the overunity.com domain and even those I can filter...
hartiberlin
Quote from: Room3327 on April 09, 2009, 04:50:55 PM
@The NOP,
    Well let's see, Only when I come to this forum do I have problems, at no other time or anywhere else on the web have I had a problem.  Not once or twice but EVERY time I come to this forum (>10 times) in the last week I have had problem.  My computer is taken over, it will not respond to me and is cranking out apparently everything on my hard drive.  My computer goes into a total down load mode and the only way I have been able to stop it is by cutting power to the computer. I have up to date virus software and a very good firewall.  I have determined the IP address that is apparently initiating this process and have locked it out of my computer, for now things have settled down.  But I want you to know how frustrating this is and I have not been able to post here during this time.  I believe either the site has been hacked, or the only other alternative, a moderator here is doing it.
Hmm,
I guess you might not have all Servicepacks updates from Microsoft installed or
your Javascript is too old.
Go to
www.java.com
and check, if you have the lastest Java updates and
also go to the free
http://housecall.trendmicro.com/
and check your PC for virusses , grayware and missing updates packs
(under advanced setup option)
This will also work, if you use Firefox.
Use Firefox 3.08.
If he finds missing Microsoft updates,
then you can just copy the numbers into Google and
it will find the right Microsoft update page, where you can
freely download the required updates.
So you don´t have to go via the real
update.microsoft.com
site, which only works with the "bloody dangerous" Internet Explorer..
Hope this helps.
Regards, Stefan.
Room3327
@All,
    I would like to thank all of you for trying to help.  I do have every software update there is for Windows XP, service pack 3 and even the latest WGA update.  I could not stop this problem from happening until I blocked a specific IP address,  This address would come in right behind a page download and take over my computer only when I came to this site. A few times it followed me when I left the site and tried to get into my computer by scanning my ports which is the first thing hackers do when breaking in.  My firewall detects this activity and automatically blocks that IP from my computer permanantly.  But I had to block that IP in a seperate block list because everytime I came to this site it was still getting in.  Now if this sounds like advertizing to you please let me know because it sure doesn't seem like it to me.  Now that I have this IP blocked I haven't been having any more problem and it came from here.
Room3327
