SPIRAL MAGNET MOTOR IDEA??
Started by magnetman12003, February 14, 2009, 01:48:55 PM
magnetman12003
Hi All,
Newtons third law might explain everything.
"For every ACTION there is an equal and opposite REACTION".
When two of the same type magnets repel one another one magnet heads one way and the other magnet goes the opposite way.  Equally.
Now in the case of the above device if one way clutch bearings on the turning disk shafts were not present both magnets would push away from each other and nothing would move. --- I might not need a one way clutch bearing on the power disk shaft. Dont know yet.---
Looking at the power disk magnet itself we see it is repelled by the MOVING follower disk magnet .  The power disk easily moves clockwise in this case and through meshed gears the follower disk magnet turns with it but in a counterclockwise direction.
Why the follower disk magnet cant move backwards is because its one way shaft bearing  transmits all OPPOSITE REACTION energy to the FRAME of the device.  That allows the only ACTION energy to move in the direction needed by the power disk magnet.  .
I am still making and gathering parts for this and its going to be quite large when finished. If it works or does not work out I plan to post it here and on the U tube.  I am having fun anyway.
Tom
Low-Q
Quote from: magnetman12003 on March 04, 2009, 09:36:23 PM
Hi All,
Tom
Well, this oneway bearing isn't a force. You prevent the wheel to spin the wrong direction, but that doesnt mean it will spin in the correct direction. The wheel will anyway feel the same force backwards as it does forward. So the wheel cannot start spinning because of the one way bearing. Magnetism is conservative no matter how you configure them. It should not be possible to extract energy from a device that does not contain energy.
However, I will never stop thinking on new ideas how I could get a magnet motor working, but in any simulation and calculations, I ends up in zero - every fu@#&cking time. I even get so excited I get sick from time to time when I am superconvinced that my new idea will work - untill I do some drawings and calculations. The same trip down every time. Welcome in the club Tom, but never give up ideas.
Maybe you could try to combine gravity, magnetism, buoyancy in one construction. Maybe there will be forces not known just popping out of something that appears to be nothing. A force which is able to move mass and some how use all these forces to extract the energy contained by any matter of this universe.
Remember that one single small grape, or 1g matter, contains enough energy to run 1500 - 2000 normal households with light and heat for one year -1g of matter!!!!! Sure it will be possible to extract tiny amounts of that energy from mass in a slow process. That also means that each year is 1 ton of matter required to feed every single houshold in this world with energy.
So keep inventing, and exploring.
br.
vidar
magnetman12003
Hi  Low-Q,
Thanks for your post. You are correct.  I am 68 years old and have constructed so many half baked ideas I lost track counting.   The day I stop thinking about this is the day Alzheimers sets in my noodle or I am dead.    Some folks drink, smoke, gamble, play cards, work crosswords, for something to do. My vice is to keep thinking about and searching the outsides of the magnetic box. Hoping to grab the holy grail of overunity if it presents itself.
I have been on many emotional rolly coaster rides when I thought something might work and then it did not.  Keeps me happy like a kid in an amusement park.  I am climbing the hill now and now expect a drop if the device fails. I just get over it and start again.  My wife thinks I am crazy but she understands. I am retired now.  I had been a commercial aircraft technician for over 35 years and all this time on my own I have tried to construct a GREEN machine pollution free motor using many different ideas.   My garage is full of magnet related motor projects and parts. If anyone is interested I have about 50 pounds of items to sell. Can send Jpeg photo. No magnets in that load.   Have a load of broken magnets to sell seperately also. Anyone Interested?
The search goes on.
Tom
magnetman12003
Hi Guys,
I just ran across this.  Has anyone attempted to build it?  Seems to good to be true.  Another Hoax??
Plans and parts list are there.
http://www.greenoptimistic.com/2008/02/06/how-to-build-a-free-magnetic-energy-generator-mini-romag/
http://jnaudin.free.fr/html/mromag.htm
Tom
magnetman12003
Hi Guys,
Here is one of my earlier experiments that used an AC powered motor with a speed control.  Needed something to do one day and made this.
Its not anything overunity but has a lot in common with the whip mag setup. Its use was exactly how the whip mag setup seemed to work continuosly on the U tube.  Drew a lot of attention then.  The powering device was not shown by the camera then ,    You can see this similar power device I made here. It will power a whip mag setup at a distance.       Became bored and moved on.            Thought you might be interested.
Tom
http://www.youtube.com/watch?v=CYFLB4irX94&eurl=http://www.youtube.com/my_videos_edit2
