Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
Onevoice
Learning something new is never a loss. I need to do some experiments... :-*
Joel
quote: The needs of the one outweigh the needs of the many - Capt. James T. Kirk
hansvonlieven
That one I agree with. Experiment by all means, you will only gain new insights. That is a win in itself.
Good luck
Hans von Lieven
itanimuLLi
How about this solution
see the drawing
firsttime start up all system is filled with water. all valves are closed
stage 1
valve2 is open very shortly to remove the air under the weight  valve 3still closed, after that valve 1 opens, weight gos down sucking in water
stage 2
Valve2 +valve3 is open valve 1 closed the weight is at the bottom air flows under the weight.
stage3
Valve1+ valve2 + valve3 are closed weight weight floats to stage1
Onevoice
That might be a solution! Difficult part would be to maintain a seal around the top where vertical pipe goes through the top of the tube. We could make that a flexible hose permanently sealed to the top of the main tank. ;D
hansvonlieven
This won't work either and pretty much for the same reason.
Have a look at my paper on hydrostatics and syphons the physics is all in there.
http://www.overunity.com/index.php?action=dlattach;topic=6836.0;attach=31031
Hans von Lieven
