Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
AB Hammer
wizkycho, Gravitator, and all
After long evaluation of this design. My findings are you would be better off taking out the piston. At least you would have better reaction for a short time, for what it is worth.
Alan
tbird
Quote from: AB Hammer on February 18, 2009, 10:04:28 AM
surely you understand why that won't work?  since the exhaust is higher than the source, the syphon won't work.  NO FLOW, NO MACHINE.
tom
It's better to be thought a fool than to open your mouth and prove it!
My brain might have some loose nuts but can someone explain to me what siphon action there is. Because my small brain can't find it. Wiz, I think you're past convincing people and have to try and build it yourself. For convenience sake you can only make a proof of concept. For ease sakes all you have to do is prove that the two actions to work separate. If they do then combined they can also work.
wizkycho
Hi all !
new anim.(not perfect)
@tbird
You just refuse to admit that 1000t (tons) can float on water. There is no sifoning effect ?? Where do You see it ?
You forgot to enter in calculation that input pipe has much smaller diameter than cilinder ...why ?
principle and mathematics behind this is simple. it is see through
Weight(MP) is changing media in which it is.
In Air this weight has its maximum weight - say 1000Kg, in water is boyant and has less then 0Kg.
You now say that this change in weight can not produce pumping (sucking action).
It is obvious You mess up your calculus and messed it up big time...why ?
I haven't offended Hans so I don't have to appologise.
@ABhammer
You are using hammer in a wrong place
Wiz  InfinityPump runs in OverunityMode
hartiberlin
@ABHammer:
Your concept will not work.
Air will come in and kill it.
You need the weight and the valves.
@TBird,
I don´t understand your problem.
You can make the weight also 1000 kg
if it will still float ( have positive buoyancy force = will swimm)
This way you will have enough "sucking power" to suck
up all the water through V1 through the small pipe ( also helped via the external 1 bar air pressure
of the environment)
and push-press down the water beneath it.
@All,
the wite space surely can be air inside the cylinder as
long as no more air will come into the system after several cycles, the system
will work im my humble opinion and will pump water infinitely.
Regards, Stefan.
