Anti-gravity Motor! (Everyone please read, very important)
Started by gravityblock, February 21, 2009, 12:42:26 PM
gravityblock
Quote from: Low-Q on February 23, 2009, 04:21:39 PM
However, an electric charged object can have the same polarity in the whole object, while magnetical objects allways have two poles. There isn't such as a magnetic monopole, right? But an electrically charged monopole is possible.
Vidar
---A snippet of your post---
Here's some more sleepless nights for you:
According to wikipedia:
(Magnetic pole model: Although for many purposes it is convenient to think of a magnet as having distinct north and south magnetic poles, the concept of poles should not be taken literally: it is merely a way of referring to the two different ends of a magnet. The magnet does not have distinct "north" or "south" particles on opposing sides.)  http://en.wikipedia.org/wiki/Magnet
We're having this discussion in another thread.  http://www.overunity.com/index.php?topic=6843.0
I apologize for the sleepless nights. I am having these sleepless nights myself.
Low-Q
Thanks for the sleepless nights ;D
I did some research what gravity is. There is some speculations that says there must be a particle, for now called "gravition". This particle is hard to find as a gravity field is a very weak force compared to other forces in matter. Scientist has as far as I know not been able to find this particle other than knowing it must be there due to the fact that there is gravity forces between two objects with a given mass.
So what has this to do with antigravity? How is it possible to get rid of these particles? It seems there is a direct connection between the mass density and number of gravition particles. So these particles are somehow captured inside the atoms. What if it is? The bond between atoms in matter are quite strong. The harder and more rigid a material is, the harder these bonds are. However the bonds streingth is as I believe stronger the better alignment there is between the atoms and has nothing to do with the amount of gravitions inside matter - like the bond between atoms in a diamond.
I think these gravition particles are doing that bond, means that these particles are many in numbers, but a very few particles seems to leak out of the atoms. The more dense and heavy an object is, the more gravitions are leaking - making gravity between objects greater. A black hole is pure gravity - a mass so dense that all of these gravitions are leaking, leaving only a gravity field left.
That said, gravity can't be removed in a mass, so there must be other forces made which is simulating antigravity.
This is only thoughts based on my wiev on the subject, so please don't see this as facts :)
Br.
Sleepless Nights Because Of The Subject Gravity AND Non-Existing Magnetic Poles, And A Son That Does Not Want To Sleep At Night Because He Has Bad Dreams All The Time.
gravityblock
@Low-Q:
The virtual particles are the force carrying particles or exchanges of particles.  As soon as they find or detect the virtual particles, then it is no longer a virtual particle, but is a real particle (such as a photon, gluon, W bosons, mesons, etc). Possibly the theoretical graviton could be the virtual particle of the theoretical Higgs Boson particle.
I don't think there is a direct connection between the mass density and the gravitons or virtual particles within the atoms.  Drop a bowling ball and a marble from a 200 ft building at the same time.  They both hit the ground at the same time.  Does the bowling ball have more mass than the marble?  Yes.  Why doesn't the bowling ball hit the ground first since it has more mass (has more gravitons) than the marble?  Gravity is acting on the atoms from the outside and causing the atoms to behave differently on the inside, such as ticking at a slower or faster rate, oscillating slower or faster, etc (which is related to time)  The atoms in both the bowling ball and marble are being influenced by gravity in the same way (oscillating and ticking at the same rate relative to each other) regardless of the weight or mass of the marble or bowling ball, thus hitting the ground at the same time.
A black hole is an object of such dense mass that it creates a gravitational field so strong that the escape velocity exceeds the speed of light.  If black holes have a magnetic field, and it can get out, this seems to imply that virtual photons (flux quanta) can travel faster than the speed of light.
There are many observable physical phenomena resulting from interactions involving virtual particles. I will list 2 of them:
The strong nuclear force between quarks - it is the result of interaction of virtual gluons. The residual of this force outside of quark triplets (neutron and proton) holds neutrons and protons together in nuclei, and is due to virtual mesons such as the pi meson and rho meson.
The weak nuclear force - it is the result of exchange by virtual W bosons.
I feel one of the reasons why physics haven't been able to have a Grand Unification of all the forces is because they ignore and completely disregard time, as most of the people on this forum does.  Let's say an object has a length, width, and a height.  This object can not change it's position or release it's energy within the universe if there is no time to do so.  Mass curves space-time. This has been proven with relativity and will remain so unless proven otherwise. Mass causes space to curve and time to slow down. The atoms in a dense mass has less room to oscillate back and forth (has less time), thus causing it to move more slowly and to release energy more slowly, thus more of the energy is being retained within itself instead of propagating out into space. The subject of time is not a productive subject due to the fact people won't even consider it to be a force, or a mechanism to release energy or to allow movement.  After saying this, I am through with the subject of time.
Low-Q
Writing from my cellphone. The earth is so big that the relative mass to a bowling ball and the marble is almost the same. I mean: earth + bowling ball almost equals earth + marble. Hence these two balls hits the ground almost at the same time. If we drop a ball at the size of earth, it takes halv that time that the balls do.
gravityblock
Quote from: Low-Q on February 24, 2009, 09:20:11 AM
If you're driving while writing on your cellphone, then you may experience gravity in your own way and know it very well.  This is what we do in the USA, LOL.
If you mean, dropping a ball with the same mass of the earth, then it will take half the time than the balls with little mass?  I believe it has to do with both the speed and momentum.
Will someone please set both of us straight......LOL
