WHY WON'T IT WORK!
Started by petersone, February 23, 2009, 06:38:41 PM
petersone
I have an idea,and I need to "reverse" a magnets pole,if a north pole approaches a piece of iron,the iron becomes a south pole,I think,if so,a shorted coil is induced by the south pole,it will produce a south pole,as long as it can't "see" the north pole it will help the north pole approach,so getting Mr Lenz to help and not hinder.
I would be happy for you experienced people to tell why it is not doable.
peter
Michelinho
Hi petersone,
If you drop a magnet in a copper tubing, the magnet slowly decends. If you drop a magnet in a tube made of copper mesh the magnet does not slow down. I tried placing copper mesh on each side of a coil on my alternator (axial air core model) and compared the results under a load on that coil and an unmasked coil, no difference. The copper mesh does not work.
Back to square one...
Take care,
Michel
petersone
Michel,thanks for your response,but I think you misunderstand my idea,or I misunderstand yours,or maybe both,I don't understand the copper,when I'm using iron.
When a n pole approaches a piece of iron,the iron becomes a s pole,if a shorted coil only "sees" the s pole it will produce an s pole,is that not correct?
peter
Charlie_V
Hi Peter,
I understand your idea.  The problem is that the piece of iron becomes both a north and a south pole.  I can't think of any way to make the iron produce a south pole that the coil would "reverse" lenz from, or atleast see only the south and not the north.
Charlie
SomedayIsle
You are not far off the unbeaten path, Peter.  Consider employing an amorphous core such as metglass:
http://cgi.ebay.com/Metglass-nanocrystalline-tape-for-MEG-generator-5kg_W0QQitemZ310127838496QQcmdZ
Or cannabalize a hard drive for some high permeability MuMetal.
http://cgi.ebay.com/MU-METAL-MAGNETIC-STATIC-GUITAR-MIC-PHONO-LP-MRI-SHIELD_W0QQitemZ400023896181QQcmdZ
Add 2 parts Wesley Gary, 2 parts Howard Johnson, 1 part Steve Kundel, and 3 parts Qin Gang.....
And you just might be off to the race(s)
