Coral Castle 50 year old secret - NOW here REVELED
Started by hammuraby, February 26, 2009, 08:42:03 AM
hammuraby
Quote from: IotaYodi on March 18, 2009, 05:38:09 PM
Fulcrums and pulleys plus a little math was all he needed.
Jmo!
hi, that is true, but you miss one thing: from where he take a  FORCE.....
is not easy to self-made one device working whit a water-gravitation alone as is show in the first post,
sorry, but i am not able to understand if you agreed whit my theory....??!,
or you think that he use a arm-force; because this is unbelivable;
Ed, was close to 50Kg heavy.....
there was this device....and now IS secreted, because if you can understand how much is powerfull in raining state;
believe me that this can make a thingS change,
expecially in a finance Oil-market...
not less than an antigravity device, because at same utility, same chage is possible;
same work = same effects
don't care if came from  a futuristic tecnology or a
rewiew of an ancient technic, IF that "done the same work!"
mirco sangalli
IotaYodi
Quoteyou think that he use a arm-force; because this is unbelivable;
Yes. A proper fulcrum and pulley setup can lift thousands of pounds. This can include inclined planes. You could set up a large weight with a pulley system to apply as much force as needed to the other pulleys.
Whether Ed used water hydraulics with it I dont know. It just seems unlikely.
Coral is perforated though, and if the coral blocks were saturated with water then it may be possible to lift it with water pressure alone. An easy experiment to do if you have a small block of coral to calculate the amount of force to lift it with water.
What I know I know!
Its what I don't know that's a problem!
Cap-Z-ro
If it was somehow possible to raise 30 ton monuments on to the bed of a half ton truck...what process would be used to stop the truck from collapsing under the weight ?
I'm thinking Ed encircled them with wire charged with a frequency known only to Ed...causing them to temporarily lose their critical mass properties.
Regards...
pese
Quote from: Cap-Z-ro on March 19, 2009, 02:33:30 PM
Regards...
Possible with frequencies.
find out the tibetan have demonstate this secret technology (i think 1942)
with 4 different musik instruments- with exactly dimensions,  as diameter of drums.
etc  (about 20 mens half circle around the
stone) that weighte tons and can ELEVETATE over 20 Meter to place this
rock to an higher place. Lot of this historical documentation was to find in
english also in german (i think last at "borderland". That was very fine described .
Possibly E.L. find that frequencies , so he can move tons of rock , with own
power ...
Possible it is to find in net... ask borderlands. archive org enz.
I have more the 10K links from last 7 jears, unsorted- i have the avove stored in head,
this is enought that you can find..
Pese
Cap-Z-ro
Hey Pese,
I recall that Ed was said to be heard singing to the coral stones...something I feel is an important component of his work.
Over on the 'joule thief' thread they make reference to the coil making an audible sound which they tuned into silence.
I'm wondering if the frequency of that sound could be tuned to accomplish what Ed did by looping the secondary coil around an heavy object ?
Regards...
