First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Alex_Sor
Dear Sir!
I welcome you from snow Russia and Ukraine :)
I know by what principle works TT :)
I badly know English language, therefore I can not write to you precisely and clearly.
If someone who well knows Russian will help(assist) me - I am ready to tell all.
In basis TT the invention which Russian inventor lays has made, and it refers to " the Artful Transformer "
But to understand as it works - I should to you tell much...
Now - "mathematics  E8" is that missing "brick" to me there were no for
construction of stable statuses " base elements " my theory.
Your  theory does not suffice the main thing - that understanding that
there are no particles - there are only "whirlwinds"("Toroidal").
It  is  very difficult to me to translate(transfer) my clause(article)
on  English language because you in language do not have those letters
and dictionary designs, whence we got our ancient knowledge.
But I shall try to explain :) would like base concepts...
We consider(count) that there are no " elementary particles "
There are toroidal formations(educations), i.e. indignations.
Indignations of Energy...
And " base elements " - toroids - look(appear) approximately so:
http://www.efir.com.ua/tmp/kv018.jpg
http://www.efir.com.ua/tmp/kv0181.jpg
http://www.efir.com.ua/tmp/kv0182.jpg
http://www.efir.com.ua/tmp/vih-volna004.jpg
Stable toroids happen different:
http://www.efir.com.ua/tmp/kv50.jpg
Most    close   experiences   on   acknowledgement(confirmation)   are
experiences with scaled toroidal rings.
That that physicists(physics) consider(count) as a particle "electron"
actually toroidal object:
http://www.nkj.ru/upload/iblock/ef2e08b542ad2a9d3598c18cf5136c69.jpg
And  that  that  is  presented  us  as  "  collision  of  particles in
accelerators of particles " - is interaction of toroidal objects:
http://www.nkj.ru/upload/iblock/48cb67dcde785299bb2a567e15160069.jpg
Concept  "a  winding  with  a  current"  which is used in ours the
electrical  engineer  and  electrodynamics(electrochanges)  - not that
other as addition of toroidal objects:
http://www.nkj.ru/upload/iblock/2b3f12e759f23457fb5f6614f9a1118e.jpg
Researches  show  that  presence of several compact whirlwinds renders
stabilizing influence on all system:
http://rc.nsu.ru/text/news/Physics/120-2.gif
In our world is not present any electromagnetic gravitational and other "fields".
There is only an interaction of toroidal structures with each other.
I  wish to try to apply " mathematics E8 " to principles of generation
(construction)  of  elementary  stable toroidal objects - to prove the
correctness:
http://www.nkj.ru/upload/iblock/021ce5a7206bdbc0d3f4fbd191f9dc71.JPG
pyramidian
Hi guys,
i built a pyramid from your plan , V6
but after some accurate research i found this is just a radio,and nothing >:( ???
crystal radio needs ,quartz crystal earphone , graphite( for diode) ,coil , antena, ground connection, and some wiering
and it do not required an external power,
you used desert sand as  quartz, coil , graphite as diode , & condenser for filtering and routing electrons across the plates, to gather with the output condenser.
the pyramid's frame, works like an antena, you must turn it to find at least one radio stations,
and you need ground !!! :D
look at the links:
http://www.techlib.com/electronics/crystal.html
http://scitoys.com/scitoys/scitoys/radio/homemade_radio.html
http://www.google.com/search?rlz=1C1_____enIR328IR328&sourceid=chrome&ie=UTF-8&q=crystal+radio
http://en.wikipedia.org/wiki/Crystal_radio
http://www.google.com/images?rlz=1C1_____enIR328IR328&q=crystal+radio&um=1&ie=UTF-8&source=univ&ei=1wXoS_a4Lsa88gaM1vDxAw&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CD4QsAQwAw
you can replace the pyramid with a standard antena,
and you will see the results .
you can also remove the output condenser and place a crystal earphone instead, and listen your favorite  radio station bye turning the pyramid to right and left,
ytinurevo
(I have not read the previous 68 pages (too long).)
Hello, I just found the german video which I don't understand.
Where can I find a translation ? All the links to D12.pdf seems broken.
What is the conclusion as for this system ?
Pirate88179
Try reading the previous 68 pages.  Everything you want to know is there.
ytinurevo
Quote from: Pirate88179 on June 19, 2010, 09:33:17 PM
How about you try summarizing the key informations on the first page where it should be, huh ??
