First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
fritz
Quote from: Tigrotto on November 23, 2007, 12:59:20 AM
1. The internal circuit is "hanging" in one point only(A), that is not a closed circuit!This looks like a microwave generator!!!
2. The calculated oscillation frequency of the LC assembly is around 8MHz.
3. Extremely strange for a DC source ( as it really is): The "shunt resistance" of the Voltage generator is "Infinite" !!! We "collect" the power from the 25x140mm capacitor! Never heard before , but... it works!
Conclusion : ? ( By now!)
If microwaves are involved (f > 1GHz) - the whole assembly would operate
different as it looks. (From microwave point of view this is no 8 MHz LC)
The coil would be an antenna - the "open system" argument would be of no
meaning,  you wouldnt identify the pulsed DC because of high frequency,
the microwaves would be recified by similar effects as with a crystal detector.
I think the reason (if we expect microwave involved) for THIS cap is that normal
caps not ment to be used with microwaves dont perform here.
rgds,
Tigrotto
@fritz,
Thanks for your special attention you paid to my posting here,
I'm proud for the fact that by my input we finally understood how to built the electric circuit.
OK!
No microwaves behaviour, also because it looks like the osc. frecv. should be around 8MHz( easy to calculate the Llegt-CCentral-Lright circuit frecq.).
I'm a great doubt:
Question for Thomas:
How did he thought the two graphite-quartsand-watersalt parts of his system?
Did he thought it as an oscillator, or maybe at a "first impulse voltage source" ?
This could help very much, even if ( see my drawing corrected definitely by courtesy of Stefan!) the oscillator is "hanging" in a one point( E- as stefan named ) !
I'm very tempted to go back to study ALL the Tesla's theory.
I repeat for all of us: He managed to "switch on " an electric bulb using only a wire!!!
Regarding my "fine tuning " method to optimize the internal filling with salt-water, unfortunately I had no feed-back from you. Except Thomas .
Please , ammend this my understanding:
Did he say this ?:
1. Prepare a mixture SAND+WATER(5%SALT).
2. Fill TOTTALY the internal of copper tubing.
3. Wait for the excess water to get out by means of the two bores
( the two bares are HOWEVER 2MM UNDER THE END OF GRAPHITE RODS)
Please Thomas to confirm if he'll have 10 seconds to read this.
Tigrotto
Thomas_Trawoeger
@tigrotto: Fill in the sand DRY!
Then make a mixture of Water+ 5%salt and press it in the left hole. If the first drop comes out on the right, stop!!
Wait 20-30 Minutes, and turn the Pyramide slowly into north.. and enjoy the Result. ;D
ATTENTION: It?s normal, that the pyramide will start with small energy, becaus there is shurely to much saltwater inside.
Give the pyramide time (sometimes more than 60 Minutes.. the energy will increase from minute to minute.
Recalibrate the pyramide?s northing after another 60 Minutes, and don?t touch the setup anymore.
Dont forget, to give the pyramide ALL TIMES some shunt, and don?t let the contacts open.
(The voltage increases incredible, and the whole effect stalls.)
If this is happening, turn the pyramide out of the north, install some shunt (user) and turn it back to north.
Do this slowly with the eyes on the Multimeter :-)
It?s not necessary to keep a Kompass, because you can see north on the Multimeter.
@all: Sorry for my angry words a little bit above: There are some guys nerving me, they tell me wonderful results, but they won?t have anything to do with this community. (This are all fools here)
I am happy to stay her as fool in a community full of fools  ;D
because i don?t know theyr Nicknames, i can?t report these guys to stefan, but i can block them in my website.
(if it is ready soon) you don?t know how to do this? (blocking IP-Groups and Maildomains would help greatly)
@REQUEST TO ALL (of the fools here:-)
Is anybody still in Construction? Is anybody willing to give us reports?
It would be nice, to give me that kind of Message, because i spent also a lot of time for you  :-*
Nice greetings, Tom
PS. Website should be Ready this weekend. Please dont register, because we will change the script !!!
CLaNZeR
Quote from: Thomas_Trawoeger on November 23, 2007, 01:24:44 PM
Hi Thomas
Do not worried we have all been called worse names than fools  ;D
I will wait for V14 when all the details are released before I start replicating.
Sean.
http://www.overunity.org.uk
Tigrotto
@Thomas,
My special thanks for your valuable support here!
I'd like to have the "privilege " as to be the first guy here replicating your pyramide and... finally posting results! I did some great steps ahead in understanding the setup, helping by you, Thomas.
Last 4 confirmations I ask you:
1. The frame is made of "square section rod"? You taked in your document of V6 about 20mmx20mm: looks like a square section!!! Or maybe PIPE (TUBE) of 20mm diameter??? Important or not, please decide and let me know!
2. Definitely: The lowest side of graphite rods are to be 2mm ABOVE the hole of the copper tube, IS THIS TRUE ??? Thanks for your filling method!
3. You said no words about the DISTANCE between the two plates 25mmx140mm of the capacitor!
Is this 1mm??? Please, confirm!
4. The pyramide lateral surface: ONLY Gypsum-paper boards???? Did you tried COPPER or STEEL? It's far much easier to built it in metal!
Thanks and waiting for your answer I remain!
