First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi all
at the end of my magnet tests, I did the following: I put verry powerfull magnets on to the frame with the magnet on top of the converter ( no change)
I put 8 powerfull magnets outside the pyramide frame ( no chnage)
the same without the magnet on the converter ( nothing)
then I took the whole converter outside the pyramide about 6 feet away and put magnets like above (no change ) but the converter allone worked like inside the pyramide frame, if I connect a seperated ground the voltage goes down.
this was the end of the magnet tests what I do. Oh I also tested with the magnets from magnetron one above , one below the converter inside the pyramide nothing not like with the rectangular magnets.
tomorrow if I got time I will test a few super caps as end capacitor, one with 1 farad, 2 with 70 farad paralell, to see if they would be charged.
greetings
walt
Quote from: jeanna on December 28, 2007, 01:35:34 PM
Quote from: neptune on December 28, 2007, 10:52:37 AM
it has occurred to me that although walt`s results are impressive, the odds against him having achieved the optimum magnetic field in the right place are very small. therefore more experiments are needed here. One possibility is to use the magnets from the magnetron of a microwave oven. These are toroid shaped, [circular with a hole]. What I shall try is to place one on each side of the copper frame above my coils. |One north pole up, and one south pole up. Then I shall reverse each magnet and compare results. I f anyone who has a converter with removable top piece beats me to it., that is OK by me A stronger field could be achieved by using 2 magnets each side, one above the coil and one below. This one experiment has given me much enthusiasm to continue .
These sound like good suggestions to me.
I won't have access to any welding equipment until the end of january and I am a beginner so it will take me longer. So, I just want to share another idea that I cannot try.
In the 60's and 70's Patrick Flanagan did many seminal experiments on the pyramid. In one of his conclusions, he says that the magnetic field is very important to the working of the pyramid. And he showed that by directing a magnetic field toward the pyramid perpendicular to any base in any orientation and getting the better results. He was not checking for electrical power but since this working model is here ready to tap the something I would love to see what happens if the a magnet is directed toward the pyramid FROM THE OUTSIDE.
Just another idea on my wish list. It will be a while before I can try it.
This is so exciting!!!
jeanna
jeanna
spacetrax
Hi,
I still don?t believe that the magnet plays an important role in this setup. OK, the voltage rises, but this doesn?t mean that it will produce some amperage...
Walt, you should put a load on the output, and also connect the long 2-plate-capacitor before you can get some decent output, I guess...unless the long capacitor was also a kind of a trick, meant to hide the real principle.
The fact that the voltage sharply decreases when the pyramid is earthed is quite mind-boggling. Normally the earth should provide the pyramid with some free electrons, but in this case it seems to act like a deep throat  >:(, swallowing all the energy the pyramid produces...
It?s a pitty that TT does not say anything anymore. Actually I believe now that he never wanted to disclose the principle.
BUT we can reinvent the wheel  ;)
Cheers,
Spacetrax
duff
Fri Dec 14, 2007 - Thomas states: "I found out, that there are some guys posting to my descriptions absolutely false details. This is not because they are stupid, this is because they want to prevent success."
It appears nobody has bothered to track down who he might be referring to and where you have been lead astray but YOU HAVE TAKEN A WRONG TURN.
skywatcher
I figured out a construction method for the capacitor without a need for soldering the copper plates.   :)
I used 0.5 mm copper because i couldn't find 1 mm, and it's easier to cut.
Central screws are M4 nylon screws, contact screws are M3.
