First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pirate88179
@ skywatcher:
Nice fabrication work there. Very impressive.
Tigrotto
Nice fabrication, yes, I agree, but it worths a slightly bit more than nothing!!!
We are here to make art, not science!!!
Tigrotto
P.S. About two months ago we started this "project". no results and I told you why! Everyone is free to go ahead !!! Even if in from of him it is a wall!
tigrotto
skywatcher
Quote from: Tigrotto on December 29, 2007, 03:33:46 PM
You may be right, but when i have started a project, i will bring it to the end, regardless of positive or negative results.
Even negative results are results. And i want to see it with my own eyes.
I had already bought most of the material before TT vanished, so it would be sensless to throw it away without even trying it.
Only if the whole case would be a 100% hoax, experimenting would be completely senseless.
If this thing ever worked, then there is a chance of reproducing it, even if this chance is very low (in this point, i agree with you).   :)
Walter Hofmann
nice work.
but there will be a probleme if this works as a cpacitor then the value would be different because the plate area counts.
greetings
walt
Quote from: skywatcher on December 29, 2007, 02:15:43 PM
I figured out a construction method for the capacitor without a need for soldering the copper plates.   :)
I used 0.5 mm copper because i couldn't find 1 mm, and it's easier to cut.
Central screws are M4 nylon screws, contact screws are M3.
georgemay
tigrotto
Hi Tigrotto,
I didn't have any positive results.  Rather pyramid is sucking all the power from the setup,  like it is connected backwards.  Maybe you will have a suggestion how to rearrange it a bit so we could try some different ideas.
Thanks,
George
