Besslers Wheel?
Started by Alexioco, March 05, 2009, 06:28:00 PM
AB Hammer
Greetings Alex
Yes it is. It was close in the drawing, I missed it :-[. Another thing to consider is the length of each arm to try to overpower the flip. The weight 4 times on the arm is a leaver and it takes 4 times the weight to equal it. So you have to determine the leverage lengths with the over balance. Adding the weights on the descending side against the ascending side. Now is there enough advantage to flip the weight. Testing will help narrow that down. Here is a test for you. Take 5 rods wights 5 weights on 1 side of a wheel and put a roller at the bottom similar to your design. Then see if the other 4 will flip the 1 and then take one off and try again if it flips. Now if it won't flip, add another arm, or no further need to finish the build as is and go back to the drawing board to see what else can be done.
Alan
Alexioco
Well, quite a few months ago, I built this small wheel, except I only had the roller at the top, I didnt have one at the bottom, so the weights just hanged down at the bottom, anyway, as i Iet the wheel go, the weights started flipping at the top with quite a bit of force, but then stopped because like i say, i didnt have the bottom roller then...
The parts to the wheel are broken now so... Im thinking of starting to make this wheel I have posted (or try to) and just plsy around with it if it doesnt work, and see how I can improve on it..
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
spacetrax
Someone seems to have made a working Bessler wheel. Read in english on the lower half of this page:
http://www.alfa-forschung.de.tl/BESSLER_Rad--k1-I-.--k2-.htm
spacetrax
Is there any chance for the rotation of the Earth to be involved in the functioning of a Bessler wheel?
AB Hammer
Quote from: spacetrax on March 07, 2009, 01:57:58 AM
dpsvryrax
I would have to be sceptically on this one. It fits the normal way cons start as well. Not saying it is a con, but it needs to be approached with a skeptical mind and wallet. We need physical proof. For even a hidden wheel will shown running, will show effects of possibilities if it is.
Alan
