Magnet motor using repeling magnets (or radial magnets if availbale).
Started by broli, March 12, 2009, 03:37:58 PM
You didn't get the point. Use the right hand rule and tell me what you get. Look at the magnet as a loop of wire! Forget about brushes and what not, just use the Lorentz force law.
Low-Q
Quote from: broli on March 13, 2009, 12:40:21 PM
You're right. I didn't see the point at first. I will lok closer to it, and get back to you. This can be interesting :)
Br.
Vidar
I realized you don't really need the outer ring, this is just to strengthen the field which will result in more torque. So the field of two cylindrical magnets repelling each other should prove the point. Attached is what it comes down to.
Low-Q
Quote from: broli on March 13, 2009, 02:47:28 PM
Hi,
This is the very same setup I tried once, except I had the rotomagnets inside between the ringmagnets. Do you think that will make a difference maybe? Because my experiment didn't work as long the rotormagnet had to follow around instead of escaping out of the system. The explanation is that when the stator magnets are facing with equal poles, there is just as many magnetic lines going into the rotor magnets as there are going out in oposite direction. So the field from the ringmagnets cancels out at the end, and no force is left for one direction.
If you look at a loudspeaker driver, the motor which is running the diaphragm uses a coil around a pole piece surrounded with magnets. This polepiece allows the magnetic flux to return to the ringmagnets THROUGH the coil. This results in magnetic lines which is going through the windings in one direction only from all sides of the coil. In your example, there isn't a path through the rotormagnet the magnetic lines from the ringmagnets are going, so the result is that all the magnetic lines are going out the same way they came in, and therfor cancels out.
The ringmagnets are often used as shielding on loudspeakers, and can be bought at any loudspeaker store where they are selling DIY-kits and loudspeaker components. I have four 6inch magnets of ferrite just for this purpose - making a countermagnetic field so my TV doesn't look strange.
Maybe there is a difference if the rotormagnets are going along the edge? I doubt, but I can try - I have all the parts needed to replicate your example.
br.
Vidar
gravityblock
Quote from: Low-Q on March 13, 2009, 12:38:36 PM
A regular DC motor is in fact an AC motor in the rotor because of the different connectors for each coil. The brushes will as the rotor spins, have contact with different coils all the time, so the magnetic force is on the same place and push the rotor away.
br.
Vidar
We have DC and we have AC.  Could there be something that has properties of both?
Take a look at the patented Sully Direct Current (SDC).  It was briefly discussed in another thread - http://www.overunity.com/index.php?topic=5293.0
If broli's device works, would it be generating this new SDC electricity?
This stuff is way over my head, I'm just throwing out information here that may be relevant to support broli's idea.
