Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: h20power on March 15, 2009, 06:34:59 PM
Now I am going to set this up as an engineering project as a result I will not tell you how to build, construct, and/or design your projects if you so choose to make them. The idea is simple, to get as many different models as possible that all work. You will be shown where the power truly comes from and how everything works for the water fuel injector system, not the WFC in use with the gasous type injectors. Read them as a set of rules to follow, anyway you see fit on how to apply what you have read is up to you.
Again I stress that this is to be a engineering type project, the full build of the design shall come from the individual and/or teams that want to work together on it. And most important of all is to have fun ;D.
Enjoy: http://www.energeticforum.com/renewable-energy/3217-stanley-meyer-explained-7.html#post47874
http://www.energeticforum.com/renewable-energy/3217-stanley-meyer-explained.html
This will be my last post on this site due to not being able to up-load pic's, from my photo bucket or my PC to this site and that hampers me from explaining anything fully. If you have questions regarding Stanley Meyer's technology and/or patents go and join the above site or just read the thread from start to end. Also this site is not run the way a site should be in my opinion, and like I said I have set out to do what I intended on doing and that was to let people see some science and math added to the Stanley Meyer patents.
Good bye Hartiberlin.
h2opower.
triffid
Since its public domain anyway,I will reveal here what I use.A salt, potassium chloride, will draw water out of the air.Then you use heat to drive the water off thus freeing up the salt to do it all over again.I would like to use solar heat.In my experiments KCl will pull equal amounts( by volume) of water out of the air.Usually takes about 3 days for maximum results.Triffid
triffid
What?No response?A 100 mls of KCl beads produces about 100 mls of liquid in 3-7 days.The waste heat that developes in a car that has its windows rolled up on a hot day could be used to drive off the water from the salt(KCl).Triffid
triffid
So a 55gal drum off this stuff would hold about 55 gal of liquid that one could pull the water out of using heat.And repeat the cycle over and over again.Triffid
newbie123
It is bizzare how many people will "explain what Stan Meyer did to run his car on water".     Yet nobody has a working water car.   We need more science and less nonsense!
Does this site doesn't even have a thread for the recent cold fusion (LENR) replication done by the Navy?    Why not talk about something more real than all this heresay (aka, everything you've read and seen Re: S. Meyer)
Until you can measure it, arguing about something can be many things.. But science is not one of them.
