Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: kolbacict on November 25, 2019, 02:26:14 AM
If this is the current passed through the cell, then the area is the number of kulons passed in one or the other direction. :)
Correct, and in physics it's known as the ability to do work. Thus if you see someone with a waveform that is only positive they are doing pulsed DC electrolysis and might as well do what everyone else does to make Faraday style electrolysis work better. But in Meyer's work the waveform is to be balanced with both positive and negative voltages being equal so in this way the work done to perform normal electrolysis simply isn't there as the two areas cancel each other out. In my experiments I have gotten the current down to just 0.3 mA which Meyer calls "Amp Leakage." This is how voltage can now do work as in this way a very high voltage potential difference can be place on the plates of the WFC which is basically mimicking a thunderstorm in nature.
In the first photo is of Max Millers waveform and the second my own. Things to note we both have the circuit hooked up the same way with the only difference being Max has just two cells hooked up in series and I have ten cells hooked up in series. Basically he over loaded the transformer and as a result it was not able to charge the negative voltage and all of that positive energy went through the water bath.
Now in the last two drawings each vertical line represents one pulse sent to the transformer with a total of five pulses sent to the transformer. When it is hooked up correctly it always puts a negative voltage ahead of the positive voltage and if the two are equal no current flows through the water bath. But there is always a little energy left over at the end that will pass through the water bath as shown in the last drawing.
Can you see just how important that question is now?
Toolofcortex
No, this is garbage, and since your gofundme efforts are dead in the water, I guess this is the right thing to call you out in order to keep the facts straight. There is a much better experimenter out there than you, his name is Valyon. Now I am not sure what his level of progress,
but it seems he is farther than you.
Unlike you, he sees value in the paper of Stephen meyers, wich is great, as it is an unexplored avenue.
You dont know more than anybody on this subject, I can go get a stranger down the street, give him my circuit, and he will have progressed farther than you.
https://www.youtube.com/watch?v=Bw4ADWjDt60&t=726s
Once we try the stephen stup, we can call it a day, and say we explored all Meyer avenues, and confirm that: The meyers were nothing but scamming trash.
h20power
Quote from: Toolofcortex on November 25, 2019, 11:39:40 AM
You Armcortex will be ignored until hell freezes over.
Toolofcortex
I guess free energy will never happen then  :-*
ramset
Arm  you feel so strongly START YOUR OWN TOPIC
please remove your Nasty comments here
some of us have much gratitude for Ed's contributions and are trying to follow and do some experiments.
if you post something that Peeps can play with ??start your own topic.
no excuses
Thanks Grandma
