Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
These differential probes are a must but you don't need to get one that handles as much voltage as the one's I have as if you build a WFC like Meyer's with 10 cells hooked up in series you can put the probe on just one of those cells which will take the voltage requirements down by a factor of 10 as the cell divides the voltage between all of the cells in the series array. Thus a differential probe that can go up to 700-1300 volts would do the trick, but only if a series cell array with 10 or more cells hooked in series is used. This is a way to get around needing to get a differential probe rated for 7.5-15 kv as the ones I got. The waveform will look exactly the same on just one of the cells in the series array as it will on all of them at the transformer connection points to the series cell array.
Anyway just trying to give you some options but do note the differential probe is required as we are dealing with a sensitive isolated circuit that is actively looking for a ground. In one of my experiments the cell was put too close to a grounding source and it created a arc to that ground which prevented the VIC from creating a high voltage potential difference. I should have taken a picture of it as it looked really weird seeing a blue glow coming from the cell to what it was grounding out on but now I only have a mental image in my head of the event and can only share my story with you. Just know it went down to the matt the cell was sitting on it's way to the ground it found the only how I found it was I heard a slight hissing sound and looked around to see where it was coming from.
I also found out that I couldn't use any circulation pump I found on the web as if the pump has a path to ground the cell would take it and would thus never charge up and I had to get a pump that had no source to ground which, for me, was a solenoid pump. I use the pump to pump the water through a filter to take out all the contaminates in the water as I didn't make the Meyer type filter that does the same thing. This is how I know Meyer's injectors simply would not work as he didn't isolate them from the car's electrical system and the battery ground would prevent the negative voltages from being created.
kolbacict
I wanted to do it so much.
To sell hydrogen, at least as long as there is, to make some money.
Money for a ticket to fly to you in California. To live in your barn, will you hide me?
h20power
Welcome to OverUnity.com
The International Open Source Free Energy Research Forum
free energy  will change the world - free energy will stop all environmental pollution
Free energy will help to heal the planet earth.
In our discussion forum www.overunity.com we talk about all kinds of free energy and alternative
and renewable energy systems.
The world will soon be very green without any pollution and any chemical fuel pollutants
with this new  technology.
What Tesla has begun in the 19th and 20th century we will now bring to
market in the 21th century.
With permanent magnet motors and Solid State magnet free energy converts into the future.
free energy will give us hope
and we will not surrender until free energy will be enabled all over the world to power cars, ships and trains and
Has this saying been the same for awhile? The problem with this is free energy devices aren't free to build let alone mass produce for the masses to try and get the prices down enough so that people around the world can afford to own these devices. Words like these is how people get the crazy idea that anyone trying to sell this technology are the bad guys. The way materials are brought and sold follows the same supply and demand curve of the markets as after all these materials are sold on the markets. Buyers whom buy things in low quantities pay a whole lot more than those that buy things in bulk which is the reason why things are put into mass production.
Then there's the ability to understand and build any of these technologies as people around the world don't have access to machines used to cut materials into the many shapes any of these technologies require let alone the ability to refine any of these raw materials. Then there is the cost of having someone make these devices as those makers will generally have a minimum make amount as they have to stop what it is they are doing for others to clear their machines to make these needed items for those whom want them made. For this water for fuel technology there are minimum buys for the transformer cores, the wire, and even some of the resins, chips, capacitors, and resistors needed to get this technology up and running. Everything has a cost to it excepts the water for the WFC's and air for the Gas Processor's. Each screw, circuit board, and so much more all have a cost associated with it but statements like these make everyone believe that when someone figures this technology out they must give it away free of charge and then everyone around the world will be able to build one for themselves which is false. People can't even follow the simple instructions I have already posted without trying to cut corners or add their spin and/or wayward thinking to it. With this water for fuel technology in the wrong hands can lead to death of those that try and build this technology along with innocents that had no idea what these people were up too. I have already seen people's cells blow up on them sending shards of acrylic in all directions.
This technology must come out by way of mass production that is safe for use, cost effective, and built to last. It must be tested to ensure no one gets hurt with a reasonable margin. People need to know how long the devices will last and/or are expected to last so that they can plan to get a new one or there must be parts of the things the will break over time available to purchase. Maintenance teams and installers need to be trained to put this technology out to the masses as well as new engine management programs and the highly trained mechanics that will be needed to work on them. All of this takes planning and time as you just don't figure one of these technologies out on a Monday and expect to have it in every shop and store around the world by Friday. Sure this technology has the power to do away with the use of fossil fuels for good but it will have a cost to it as it isn't free as materials are needed to make them, labor from people to assemble, install, maintain, troubleshoot, and fix them, plus teachers to train all of those people. Why people on forums like these never talk about these things is beyond me, but I guess as a whole they are trapped in some form of La, La land [size=78%]https://www.youtube.com/watch?v=KvCsfqbPWzo[/size]
I simply don't understand why talks like this are not dominating the forum as we need to be honest with ourselves and what it is we are trying to accomplish. We need to come back down to reality and deal with the world we have and not the worlds we create in our heads that don't actually exist. All of these technologies will take some major planning as we are trying to replace the use of fossil fuels which has been apart of our lives for many generations now. All those that sell energy do not wish to stop doing so and governments have went to war to obtain these fossil fuels killing millions of people in the process. In order to topple these powerful institutions these technologies will need more than the full support of the people as they also need people that will move to see these technologies through till completion. We have so much work ahead of us and we will have to fight those that do not wish to stop selling energy to the masses in no matter which form they use to put energy on the grid systems around the world. Are you folks up for this fight where on one side it's filled with people like me with little money to do much of anything and on the other side people with so much money that just one of them can feed the entire world and still have money left over to do what ever they wish to do with it? It's going to be a war of the have's verses the have nots as many of the have's do not wish for people to be free of their energy enslavement situations they find themselves in today. We must stop fighting each other and come together in one accord if we are to have a chance at toppling just one of these giants let alone all of them.
And to Kolbacist, True Green Solutions isn't hiring anyone at the moment and we do not provide our workers with a place to live. Sorry.
Shalom Everyone,
Edward
kolbacict
A constant current of the same magnitude was passed from the power source, which was recorded in the thyristor pulse circuit. The evolution of gases is visually the same. Again, everything is according to Faraday's law.  misfortunes are pursuing me again ...  :'(
kolbacict
Why then does the decomposition of water not occur in Marx's water generator?
There, really, very high stresses are present on the plates.
And the frequencies are quite large, units and tens of kilohertz.
Which are determined by the time constant RC.
Less is simply impossible due to the self-discharge of a capacitor with a water dielectric.
But we do not observe any signs of decomposition of water into hydrogen and oxygen.
