Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: Vortex 22 on May 09, 2022, 12:02:30 PM
We all know how to charge a water capacitor to it's voltage dielectric breakdown ! ! ! There is no magic about that
We can do that using only  milli amps.
But it's possible to do that using only voltage and zero amps. I have done that many times with the mains ( 220 v ac / 50 hz)
So it makes sense to try it using high voltage and high frequency
! 10 kV / 30 kHz !!!
But
Can we have the same results using only 220 v and 50 Hz ?
If you build a cell with the plate spacing really close say around .001" then that might be possible, but for a cell built to what Don Gable shared with us works only when the voltage potentials are 1kv per resonant cavity. So, if you have a WFC with 12 resonant cavities then it will require a minimum of 12kv of potential difference to get it to start working as each resonant cavity in the series array needs 1kv to reach the threshold for ionization of the atoms that make up the water molecules, IE, hydrogen and oxygen atoms.
But at any rate what you are speaking about would need to be tested in the real world not just talked about in order to know if it would work or not, but the waveform will still look like the one I showed at that is the primary means of restricting amps from flowing through the WFC. I ran a test that showed a drop in the required voltage needed that had a plate spacing of 0.032" instead of Meyer's 0.095". I have even built a cell with 0.010" plate spacing as shown below. Basically what it all comes down to is learning how to build the transformers correctly and that will only come from trial and error type testing the old fashion way.
Shalom,
Edward Mitchell
CEO and Owner
True Green Solutions
https://www.gofundme.com/f/energy-independence-for-you-and-me
Vortex 22
Quote from: h20power on May 09, 2022, 09:46:48 PM
Shalom,
Edward Mitchell
CEO and Owner
Thank you so much !!!
Vortex 22
The best materials used for WFC construction, according to the water pH level?
h20power
Quote from: Vortex 22 on May 10, 2022, 01:16:30 PM
The best materials for the housing to use are Delrin, Acetal, and Nylon, but you can also use some Acrylic so that you can see things but it is not necessary. For any metal that comes into contact with the water you must use Stainless Steel.
In the future True Green Solutions will be offering kits that will allow people to become energy independent but for now I must keep to trying to raise the capital I need to make this dream happen.
Shalom,
Edward Mitchell
CEO and Owner
Vortex 22
Quote from: h20power on May 10, 2022, 06:44:07 PM
Shalom,
Edward Mitchell
CEO and Owner
It's very nice to hear from you!!
Thank you so much!!
I pray for you success !!!
God Bless You
