Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
PaulLowrance
CLaNZeR,
Do you have something similar to mylow's device with low friction bearings? If so, then could you please do a simple experiment that mylow continues to ignore despite all the times I've asked him to do. Get the machine spinning at the same rpm shown in mylow's video, and see how long it will spin. If your stator PM is stronger than mylow's then please replace it with a similar PM or remove it for the test.
Thanks so much!
PL
Omnibus
@CLaNZeR,
Keep up the good work, mate. That's the way to go, not by beating the drum in the town square before the child is born. Good luck.
CLaNZeR
Quote from: sterlinga on March 25, 2009, 02:29:19 PM
Oh, he said the bearing in the bearing assembly goes all the way through the aluminum cylinder.
Interesting quote as the Botom plate with the stubby sticking upwards that enters the Bearing is only so long anyway, so do not see whay this would matter ?
http://www.overunity.org.uk
mikestocks2006
Quote from: wattsup on March 25, 2009, 01:39:56 PM
....That's it. As shown in my next drawing that will now be my build spec. One neo magnet per rotor or stator should give about the same result and not be subjected to field losses. The field loss is what is concerning me the most. Also, with neos embedded into the iron stock, I imagine the distance between the rotor and stator will still have to be greater then what Mylow requires given his very weak magnets...
Nice work,
In addition it will allow for a great range of magnetic strengths and even composite orientations, without altering the basic rotor/stator dimensions.
Thanks
pillager
Quote from: PaulLowrance on March 25, 2009, 02:35:13 PM
Indeed. Do you have any connections to notable scientists, perhaps even a University physics professor, that would be interested in testing this? So far the machine has always demagnetized the PM's. Initial very rough estimates of the energy contained in the single stator PM comes to a few joules. The power required to maintain the low rpm is extremely small. I recall years ago calculating the energy required to maintain a slow spinning bicycle front wheel was ridiculously low. Sorry, don't recall the exact numbers, just the outcome. Also, IMO all 63 of the Alnico PM's are degaussing, but at a slower rate than the stator. These are simple measurements a University physics professor would measure so we can once and for all determine if it's legit or not.
PL
This device is simple enough that it can be easily replicated.  The last thing I would recommend is take it to "professionals".
If replication is successful, then the universities can replicate it themselves.  How many posts have you made on this? 50? ...WE HEARD YOUR POINT...MOVE ON PLEASE....
