The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
wattsup
@AhuraMazda
That is a great Hendershot photo and I am surprised to see regular transformers. Could they be specific audio type transformers.
Things are really really crazy. Just last night I was thinking of putting a metal cylinder inside this new build I made a few days ago and started testing. Then I see your photo of Hendershot and look what's inside the rings. It looks like metal cans. Could the metal can reflect the outer pulses back onto the coil to give a double shot. One from the vertical and one from the vertical reflecting back. Could this be the shadow effect?????????
This new build is a 12 vertical on a 12 loop.
AhuraMazda
@Wattsup,
I want to do exactly what you have built in your current picture but, with a lot more precission. Basically you join the red wires ( in series / parrallel or combination) then you pulse them. DC pulses? sinosoidal or square pulses? You are trying to setup standing waves corresponding to the gap between the nodes are. If you were to squeeze the water hose, you would not squeeze the same point so, there should be a bit of slip.
I am sorry about my Stan Meyer style technical speech. it is 3 AM here!
I wish you success.
otto
Hello all,
guys, dont complicate the TPU!!!
The control coils are ONLY to control the TPU so it cant go out of control!!! Forget the control coils until your TPU is going into a runaway. THEN and only then you need the control coils.
Concentrate more on the collectors and CORES. This is  1 of the important parts of a TPU.
You all should know that when you pulse the collectors you can light a bulb without any problems. So why to f...k with controls? They are wound like oridinary coils, nothing special.
I will give you an idea how the controls are working:
the most of you have cars. Youre driving this car at a certain speed. Now imagine you have to slow down. Look behind the cars wheel. Isnt there a disc? Isnt there a brake? Good enough for a car.
A TPU is a "disc". The controls "wound all around" are the brakes. Why have we to wind our TPU brakes all around?
Because we are working with very high accelerated particles (very fast car) and this is the best solution to slow down this  particles inside a TPU.
And the best solution are controls wound in a classic way, to say so.
Have you ever pulsed only collectors and measured the current from your power supply?
Have you then connected the controls to the collectors and then pulsed them? Measured the current?
Of course, if you pulse controls + collectors, the current from your power supply is bigger. Why??
Not because of the bigger wires resistance. NO! Control coils are extremly short.
Its because you have mixed apples and bananas, ha,ha.
You have mixed the horizontal flow of the particles in the collectors and the vertical fow of them in the controls. They are fighting. This fight causes a dramatically current rise from the power supply. The particles in the controls want to accelerate and you are slowing them down with the vertical particles from the controls. So, the end result is in a dramatical current rise fron the power supply.
Now the question about core or not core.
First give me a patent for a device like a TPU, or a generator or......without a core. Show me 1 of the "big brains" that didnt use a core inside his device. Tesla, Bearden in his MEG,......
Now find the analogy about cores from SM. Didnt he say something about a  iron car motor, that a Aluminium motor is better.....my memory is really not the best.
Heeeey, with a core I have much more energy, to say so, in my coils, a core doesnt slow down my particles, the current from the power supply doesnt rise.......so why not a core??
And not to forget, my core is the connection to the ....hmmmm.....aether or surrounding "aer" or the cosmic rays, or, or....call it how you want.
Do you see that I didnt mention tubes?? Im still waiting for a rectifier tube from Germany. A 5U4 tube.
But tubes are a special story for really bright people. I mean for people who can think outside the "box".
Otto
AhuraMazda
Hello Otto
Thank you for all your information. Do you have a picture or schematic of your latest TPU design?
The point with all this development is to design a device that would generate electricity on it's own.
I know that you have done a lot of work with different configurations of coils and have a lot of fun doing it
but still the big question is outstaning and that is does your coil self sustain and produce additional power?
There are many 5U4 tubes if your German supplier fails.
AM
otto
Hello all,
@AM
I have a lot of informations but I dont think the people here are open minded enough ....never mind.
no, I dont have a self runner, not in this moment. A self running TPU would mean that such a device is working near a runaway point and we have the knowledge to control it. Its no a problem to get into a runaway. Its not a problem to blow the equipment. Its a biiiig problem to control the beast!!!
As Im waiting for my 5U4 tube Im playing with my TPU and my life. The recitifier 5U4 tube is needed to get a DC high voltage mixed with an AC voltage mixed inside this tube. Then this voltage stepped up to maybe 20kV. How else to ger such a voltage??
Yes, a little step up transformer......I know it but......tubes are in this moment a MUST. Not because of fine and clean signals. F..k them. I have now perfect clean signals without tubes. Made just with SS!! The vacuum tube is the best known "connection device" between the aether, the surrounding energy, the.....and a TPU!!!
Not so easy for me to explain. A tube is like an antenna for radiant energy. Somehow it recieves the high frequency particles from the outside and then converts them to a lower frequency, higher energy .....
The same is doing a "CORE" in a TPU. It recieves particles from the surrounding and when you have luck or knowledge to vibrate this surrounding....
Sounds like an idiot is out of control....
No, I dont drink. Have a nice weekend.
Otto
