The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
supersam
dave,
is there any way to get that doubled sign wave, "kick" into one of those capistors?
sam
mrd10
Quote from: giantkiller on October 10, 2006, 07:45:15 PM
@Starcruiser
We know that loop antennae when facing the source of emmisions will show the strongest signs of reception. Our source now just happens to be in the center. The diameter or radius of the loop has to, in our case, matche the effective wavelength of the harmonic freak wave of the 2 freqs harmonizing together. The freak wave being made up of the spikes off the square waves. Geez, they would be huge. Then connected to the loop you would have an lc tank tuned between the 2 starting freqs to pass on the captured freak wave power. Or why not just a diode bridge and extract it all. So 3 things have to match, the 2 freqs for the harmonic wave, the distance of the loop antennae, and the loop coil windings. What if one would use exite the top coil with one freq and the bottom coil with the other freq and the collector just sits in the middle. That way instead of trying to match 2 electrical freqs you actually are letting the magnetic freqs do the work. Oh, sh*t! especially if they are counter rotating? The interference would be larger across the collector/antennae.
Do I have log in my eye or isn't anybody else seeing this? ;)
We still have 3 things to contend with:
1.) Self starting or not (I don't know what's here, but if you solve #3 the rest will probably solve themselves by working backwards.)
2.) The toroid having rotational and gyroscopic qualities (segmented air( for not saturation, total field collapse) coils)
3.) Immense power out (the product of the square wave bemf harmonic tuned antennae/circuit)
Hi Giant Killer, your right, spot on, I noticed this, from his first early prototypes, he is using two rings, its evident that all the other ones are probably designed the same way, so you produce two frequencies on each ring and power which is collected is in the middle, something like that, I think we should stick with his earlier design, Thats what I will be starting off with anyway, just wanted to know if any other builders have gone this way.
mrd10
Hey Dave,
Before you go on leave, regarding the transformer experiment you did, if its easy enough for you to do, could you try 4 transformers, i.e 3 are fed with sinewaves into the 4th output transformer, i'm just curious what would happen. Also I'm trying to understand what your doing with the caps and inductor, maybe in lamans terms you could explain it, sorry if i ask, just my level of understanding at this time isn't upto scratch, I know ive got some reading to do. I used to build kits and my electronic theory needs abit of a refresher.
Cheers Champ,
Dom    :D
mrd10
Hi Dave,
Again, sorry my understanding in antannaes and coils is simple at best, I'm new to this stuff and i don't understand fully how the earths magnetic field plays in all this, I was probably just going by what sm said the electrons in a wire interact with earths magnetic field, this i guess he was talking about his kicks.
Your right about his second version, there two rings which look bare, and though this maybe the case, its still two rings and i feel its this type of setup that will somehow give us the result. Again sorry im still new to this coil building and need to learn this, so im just looking and observing how he has them setup.
The first coil his made, correct me if im wrong he looks like he has bailing wire on both rings but in 4 segments in total, i.e two ontop and two on the bottom, and going by what giantkiller was saying, applying one freq on one, and another on the other might be whats making this work.
again im thinking KISS
lol
Dom    ;D
mrd10
Hey Marco, tell us please...more detail.....lol
2 rings, 2 rings, 2 rings , 2 rings         some coils
2 rings.....could this be all        guys think of his early ones  the first videos made
2 rings
hmm potential between the two    2 rings    do i know what im talking about, do i sound like an idiot....maybe
but maybe we need to look at this from a fools perspective, and that can be me...i have no shame
2 rings
Dom    ;D
