The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 59 Guests are viewing this topic.
dutchy1966
Quote from: ctglabs on October 21, 2006, 10:34:33 AM
But I believe there are other ways to acheive this using bucking fields (of a sort).  I am testing something at the moment.  If there are any results I will of course post.  TPU could have colliding fields too, which give it the interial feel, not sure.
Hi again,
Yes, you're right. It is ppossible that way, which brings us back to Tao's drawing where the control coils are creating bucking fields. I think you still need substantial voltage for it though.
Dave, are you able to test something like that? Wrap up two coils, and lengthwise put a stout wire through it, create bucking fields and see if there is a voltage on the stout wire? This would be an outcut of the toroid..... If the TPU is based on that then this little test should work too!
Dutchy
starcruiser
Quote from: ctglabs on October 21, 2006, 11:07:33 AM
Hi Carl,
I can see what you are saying with the one way signal!  I have tried some 90 degree coupling with square waves.  You are right, because the signal in the secondary will not be square or spike, it will not have any backwards coupling!  But is this of any use?  Its like a magnetic diode?!  It also makes the system asymetrical and as such not in equalibrium.
Kosh has just mentioned the capacitance between the coils, so the coupling we have seen so far could be electrostatic induction, since there is no magnetic interaction between the coils.  This explains the weak interaction.  Most of the energy is in the magnetic field.  So using the electrostatic field here is not efficient?
My solar panel analogy does go with your theory, perhaps I didnt read it properly?  I thought you wanted to receive a signal and feed it back.  If we take that to the solar panel and we simply have a solar panel and a bulb and we feed use the light from the bulb and shine it on the panel and use that to power the bulb, it will not work.  Only 15% of the light from the bulb will be turned in to electricity, so the thing will stop immediatly.  I though this what you mean with cyrstal radio feedback?
But if you have the sun on the panel and use the panel to power the bulb and shine the bulb on the panel too, you can start a loop because there is always extra coming in from outside the system.  So I guess what you were saying is, continually receive an outside signal and feed it back too and see if it can build up...
Regards,
Dave.
you got it Dave, outside plus inside feedback will increase overall output, even with a minor increase this will keep regenerating until it gets large enough.
There is some radio and antenna theory that speaks to regeneration and signal swamping the tank circuit (this relates to the local feedback via the large torrids magnetic field). I am thinking this is worth investigating.
Regards,
Carl
Regards,
Carl
c0mster
Gad all these ads are ridiculous. I feel like I am being spammed by ads. Surely you can find a better way to make money off this site instead of bombarding us with ads.
dutchy1966
Quote from: ctglabs on October 21, 2006, 12:47:53 PM
Quote from: c0mster on October 21, 2006, 12:32:26 PM
I agree, its a bit crazy!  I can't even read german!
Dave.
Gn0sis offer to move there still stands......
www.gn0sis.com
c0mster
I agree, the time it takes to load these ads may be small but when you have to read an average of 25-50 posts it all ads up. If there were no ads there could be more posts per page. Anyway I?ll keep checking gn0sis site, I did a ping on it and it seems to be alive so he must be working on it. When I first started viewing this site a few years ago there were no ads, my how things change.
C0mster
