The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
c0mster
Steven or atleast the guy in the video says the unit is 12 Oz. How much wire is 12 OZ's? Not Much.
The patent application is the Gunderson device.
C0mster
2tiger
Hi all
Since I began to read this thread, I often think about the words/hints "... like squeezing a hose...".
Have you ever heard about the skin-effekt caused by alternating current?
Quote from Wikipedia:
The skin effect is the tendency of an alternating electric current (AC) to distribute itself within a conductor so that the current density near the surface of the conductor is greater than that at its core. That is, the electric current tends to flow at the "skin" of the conductor.
http://en.wikipedia.org/wiki/Skin_effect
The skin effekt increase the resistance of an alternating current conducting wire by increasing the current desity on the skin of the wire.
So if the current density near the surface of the conductor is greater than that at its core and high current means more electrons in a certain space, what is in the core of the wire, no electrons? Nevertheless it becomes high ohmic. But what is highohmic? Does it mean that there are less electrons to create current flow?
I don?t know, but let me assume that.
Now imagine a multistranded, non insulated litz wire, send high alternating current through it. The current density on ther outer litzes will increase, and the inner ones are "empty/ less or no electrons" -> high ohmic.
Connect now a DC current on the inner litzes for a very, very short time, perhaps microsenconds. In the same time switch off the alternating current
My assumtion is now that all the electrons that where collected on the outer litzes by the skin-effect will collide with the "few" electrons you put in the inner litzes by connecting the DC current.
Cann this collision be the kick we?re looking for?
Well rereading this reply I have to admit, that it is a poor theory. But I have also to admit, that I have no other idea, how this device could work.
kr
2Tiger
mkt3920
RE:  Magnetic Fields
Quote from SM via Mannix:
<<The meter measures anything powerful in regard to electron flow based on the strength of magnetic field.
So the meter displays that there is OBVIOUSLY a LARGE magnetic field inside the coil!!!!!
If the meter says five amps just from a contact high, that means there is one helava lot of power spinning around inside there>>
sparkman
2tiger,
At this point your theory is as good as anyones. I suggest you expand your theory and build a experimental test setup. See how many of the observed characteristics of the SM devices can conform to your theory.
Sparkman
mrd10
Hi All,
You might find this very interesting:-
http://mrsec.wisc.edu/Edetc/cineplex/NMR/index.html
Nuclear Magnetic Resonance
Oscillation frequencies of the compass needles decrease with increasing distance from the magnets on the left.
Gives you ideas doesn't it
Dom
