The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
simonmagus
Has anyone experimented with iron fillings to visually examine the magnetic flux?
http://physics.usc.edu/demolab/mg_magneticfield.html
eldarion
@Otto,
I have tried your test circuit again with the attached schematic; I could not get anything interesting to happen.  Is the attached schematic correct?
I stopped blowing up MOSFETs once I tried frequencies above 100KHz; is this what you found also?
Thank you!  I would really like to get this working ;D
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
eldarion
@weri812
I'm sorry, I don't see the difference? ???  I must be missing something (not the first time!) ;)
-- Thomas Paine
otto
Hello all,
as I can see NOBODY has my results so I have to be specific:
use this:
1.IRF 840 MOSFET - only this type
2. make 50 turns with a copper wire. diameter 0,5mm!!! sorry I dont know AWG...
3. lamp wire or speaker wire or...litz wire with a plastic insulation
4.connect everything like in my picture
When you have the right results everything will be clear and then you will understand why this test is IMPORTANT!!!!
Otto
