The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
rensseak
Quote from: tao on June 28, 2006, 01:24:22 AM
AWESOME picture.
Can you do some more pictures with the magnet in different positions so we can see the magnet's field?
Like try the magnet flipped over, rotated 90 degrees, etc..
Thanks either way.
You look here http://mindprint.dyndns.org/trmweb%20II/Magnete_Feldlinien.htm and scroll down.
Anziehung=attraction
Absto?ung=repulsion
regards
Norbert
rensseak
Quote from: HMM on June 28, 2006, 03:03:33 AM
Hi group,
energycoils-full-vid screen shot
The bottom arrow shows wires hanging out from the cut, top arrow shows what looks like more wires I will post better screen shots soon.
thanks Tao for the help
The video shows a TPU being cut and the Engineers take meter readings from coil ends and various locations.
;DMike
Is it possible that you upload this video so that everyone can watch it?
thanks
Norbert
HMM
Hi Norbert,
The video I have is to large to post (173Mb)
I will figure somthing out.
one more shot from the vid
Is this the magnet holders?
;DMike
bob.diroto
This is a summary of where I am in my thinking and experiments:
SM, I believe uses the term ?Control Wires? in the very broadest sense meaning wires involved in the input and output of the TPU. Because if you are feeding some of your output back into the input the output could be thought of as control wires.
High confidence this is correct.
SM has said there is a rotating magnetic field in the empty center of the toroid and it is this field which induces the voltage and current in the output coil. In tao?s model the output coil would be the very outside control wires. This is further backed up in that SM has stated a compass rotates slowly at first and gradually picks up speed and then eventually stops. It is my belief that the compass stops rotating because the magnetic field confines itself to a small circular area near the coils. If the magnetic field is their the compass will rotate IMO. QED no rotation, no field moving over the compass.
The Kicks
I?ve not been able to get a useful measure of the ?kick? effect. I?ve confirmed that shorting a battery with a jumper cable, as per Mannix suggestion, does result in the cables jumping, but it is more like a  twitch. As per several of my postings I?ve tried linking an outside tube made of iron wire, into a parallel LC circuit to see if energy could be enticed to build up in an LC circuit. Not a sniff of anything unusual. My thinking here is that my circuit is not isolated enough. I have not yet tried using a transformer to pulse the high voltage into the circuit. SM does specifically mention that transformers were part of his discovery process. SM says unusual things can be observed (oscilloscope or spectrum analyser ?) when two high voltage transformers get slightly out of phase.
My assumption is that the ?kicks? are linked to Tesla Radiant Energy which has an electrostatic component. Radiant energy requires metal objects to be of a certain size, shape and mass, for it to collect on a metal object.
This is my number one aim. To get some kicks and make some measurements. Anyone got this working yet ?
Frequencies
There are lots of numbers bandied around:
SM has said 7.3 Hz vibration in one of his devices.
SM has also mentioned 6000Hz component, in the pulsed DC output.
174.9KHz is the frequency of magnetism.
It can be seen in the video that the output is very high frequency judging by the ?fire? effect of generated sparks when output wires from the TPU are shorted.
He has also said the frequency is related to the circumference. To get a wavelength within the length of wire in one of the coils would mean frequencies in the gigahertz range ?  Or perhaps this is a way of saying standing waves are required ? Or perhaps this is a cryptic way of saying that resonant circuits must be used as the diameter of a coil affects the impedance of a coil which in turn affects the resonant frequency. Parallel resonance is an effective open circuit on the power source (infinite resistance). Serial resonance is an effective short on the power source (no resistance). I?ve been thinking whether these two effects can somehow be combined to good use. Parallel resonance for the input coils as it would use very little current to drive the circuit and serial resonance for the output coils in order to have very little resistance.
Permanent Magnet
My latest thinking on this is, if the earths weak field causes a small kick, then the much larger field of a permanent magnet must enhance the kick effect. But I?m buggered if I can measure any kick effect, permanent magnet or not.
Batteries
To me, this is a no brainer. Batteries are used to get things going. Once we understand what is happening we can close the loop of output back into input power.
Electrostatic and high voltage
Patrick Flanagen has a 1988 patent for an Electron Field Generator. It requires high voltage (5000v) AC pulses applied to two fully insulated plates. Plates are cast in epoxy resin. Diagram on patent is self explanatory. The end result is a cascade of electrons (in the environment). Perhaps there is an element of this effect as insulated coils could be thought of as stretched out plates.
My Step by Step No Working - Energy Building Process!
1.   Generate kicks ? it doesn?t matter how much battery power at this point is used to generate kicks. You need to have some kicks. No kicks ? no TPU. I?m still stuck at trying to get some kicks.
2.   Turn one kick into multiple kicks. 150khz high voltage pulses in theory generates 150,000 kicks per second. Have two coils both with 150khz, and say 151khz pulses and have these both going to a simple transformer so both inputs interact with each other and perhaps something ?strange? happens. Throw in a permanent magnet to make the kicks bigger.
3.   Collect electrostatic energy from the kicks ? iron tubes cut to right length, mass and size.
4.   Turn electrostatic energy on the tubes into rotating magnetic field. My only theory so far is to somehow rotate where the kicks are coming from and perhaps this generates a rotating electric field which in turn gives a rotating magnetic field.
5.   Rotating magnetic field induces high current and voltage into output coil.
bob.diroto
Quote from: Mannix on June 28, 2006, 04:26:08 AM
Hi all,
Perhaps I need to qualify something.
At this stage this thread is for those who ARE winding coils. Information and discussion WILL come up to a pace where we can all get on the same page.BUT if you do not have the basic test equipment and aren't prepered to put lots of effort in then be honest and just watch...do not contribute unless you are hands on. I apolagise if I have offended any body ,I am just trying to give this the best chance of success.
If your ego gets bruised by this ...you need a thicker ego. I know I do sometimes.
If any body that is hands on,has the necessary skill, works with high voltage, and is prepared to spend much spare time chasing this Please let me know.
I am going to get us all to the gate at the same time and not be slowed down by those who have just arrived. This has been going for months now so For those who have just discovered this Please Take the time and read everything.I imagine it will take several nights to read and several weeks to absorb.
As stated, very early on this will never be monkey see monkey do ...mabey nothing will be achieved except the journey I dont know..what I do know is that we cannot keep slowing down to the pace of those who come in late.
Plenty of people who are well trained an have passed many memory tests have in thier mind, very good reasons to say that this is impossible. For you people please just leave us dreamers alone and do a crossword. Success is just a matter of time and some hard work for the rest of us ,and the more productive we can spend that time the better.Its still free to watch The last thing that we should have here is a closed shop...If it comes to that this whole thing will be a failure of sorts.
Please pm me with your experience and equipment..lets get going.
Lindsay Mannix
Mannix, I totally disagree.
I think it is only your perception that things are slowed down by other people posting and 'coming in late'. People are mostly slowed down by work and family commitments. People don't have a straight run of time. I get 3-4 days spare if I finish a project early.
I would appreciate more of your involvement in the ongoing discussions and theories raised.
What do you think causes the rotating magnetic field ?
How are you getting the kicks ?
What mechanism are you using to get multiple kicks ?
How are you collecting the kick energy ?
What mechanism are you using or thinking of using in order to convert the static energy into a rotating magnetic field ?
What parameters have you determined for efficiently collecting kick energy ?
I know you've posted the 'all the kings men' story but honestly why introduce another layer of interpretation. Why not actually tell us exactly what you believe, why you believe this, what experiments you've done to confirm your theory, and whether SM has confirmed your beliefs.
Why not start another thread with the opening message, This thread is for contributors who are building coils please post on the other thread if you are not building coils ? Perhaps on this new thread you could post any other information from Steven Mark that you have not yet put onto the board. Why you hold back information I have no idea. That last personal message was crucial. Could have saved me a bucket load of time if I had it earlier.
I for one would like to know:
How long had you been holding onto the last particularly valuable information from Steven Mark ?
Do you have any other information from Steven Mark that you are not posting at this moment ?
Why drip feed the information ? Let's get all the information on the board.
I have a 35MHz oscilloscope, 3Mhz Function Generator, and a shed full of old parts. I'm familiar with high voltage, rf precautions. I never wear a watch or jewellery when in my experiments shed. I'm thinking of obtaining a spectrum analyser (I know a two way satellite guy who may have one going).
