The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 989 Guests are viewing this topic.
hartiberlin
If he turns his device by 180 degrees and the output goes down, then it seems to matter, in which spinning direction he is cutting the earth magnetic fields , or am I wrong ? What could be still a different reason for this ? What puzzles me is, that he is demoing it above some measurement equipment, where the case is probably made of iron so it would shield any earth magnetic field... so why does the output decrease when it is turned by 180 degrees ?
oouthere
I believe you are looking at the earths magnetic field incorrectly.  The field runs from from pole to pole, not straight out from the axis and into space so he could probably run this thing on top of a car and it not effect the operation.  Another guess is the closer to the north or south pole the device is operated, the more power is produced since the fields are more concentrated.
Rich
hartiberlin
Paul G Stemm, Universal Energy Corporation, Bank Underwriter, Lawyer,
Lives with his girlfriend in the
Philippines,
wife and two children , live in Irvine, CA, has not practised law in 20 years. Peninsula Court
Bldg, Suit 413, Metro Manila Phone 011-63-2-810-9284/8945358. Ah
8193856, 8735 Paseo de Roxas, 1200 Makati, Metro Manila
hartiberlin
I have watched the video again today and the unit which is shown without the tape wrapped around it,
which powers the 2
standing lamps.
In this unit one can ?clearly see, that there are several short turn coils
wrapped around the lower side of the toroidal core.
So I guess, if this unit is producing a rotating magnet field it must
be controlled by a 90 degrees phase shifted sine wave or other 90 degrees
phase shifted wave, like a square wave or something simular.
Let us assume he uses 4 driver coils each 90 degrees space apart,
each on a quarter legof the toroid and each pair is controlled with a 90 degrees
phase shifted sine wave oscillator, powered by a single 9 Volts battery.
With this he could generate a rotating magnet field inside the core !
How then can you design the output coil or coils to extract more energy than
you put into the 4 phase shifted driver coils ?
Any idea ?
Maybe the output coils are located beneath the low turn windings
driver coils and have more turns ?
How could these be wired to violate lentz law and defy the transformer
principle ?
