The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 252 Guests are viewing this topic.
hartiberlin
Please all, let us concentrate when you post here in this thread
onto just the technical details. Please no flamewars.
Thanks.
hartiberlin
Please can somebody post an experiment,
where one can see, that a current impulse in a conductor  is
amplified via the earth magnet field ?
How could one design a circuit which would show this ?
I can?t see how this should work.
Thanks.
Regards, Stefan.
Lebt Klaus Rassbach noch,Herr Stefan Hartmann ?
Addresse:Berlin
Hoeflichst und mit aller gebietenden Hochachtung
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?de Lanca
p.s.:Hanna Albert Awad,irgendwo im Libannon(Ajaltoun,Kerouan),
mindestens ein Anruf wert
Elvis Oswald
I thought I would chime in with my 2 cents on this subject.  :D
Two things I think are very important here.... and I could be  wrong... ;)  (ask me about routing IP traffic and I'm 100%)
#1 In one of the videos Steven say's that the device is resonating at about 7.4 cycles per second.
#2 The continued references to tubes.
Tesla used a device to power an electric motor (in a car) that used vaccum tubes to amplify his source - which was apparently the resonant frequency of Schuman cavity.
I'd also like to add my 'hurumph!' to the notion that education might hold some of you back from a revelation in this matter.  If Tesla used technology from 100 years ago to tap the aether... all we can really be sure of is that it can be done with that technology.
So my contention is that there is 100 years of technology branching away from the truth and towards the constraints put in place by evil men with greed as their motive.
rensseak
Quote from: mannix on February 07, 2006, 01:41:45 AM
ROLAND SCHINZINGER PhD.
Report on Test of Energy Device
After the test the inventor cut the toroidally shaped device into segments (though not the controller box located at the center of the device). These samples consisted of an array of circumferentially arranged coils and wires grouped around a core made of a cork like substance.
October 29, 1995     Roland Schinzinger
Quote from: mannix link=http://www.keelynet.com/interact/archive/00000596.htm
So here is what i have found out 22 turns of 23/0076 lamp wire around a 10
inch wood former . there are capacitors but no info on them. I have used a
14 inch wheel plastic wheel trim with 22 turns of lamp wire and ,wavin a
magnet over the coil gives a rf output which i have not been able to explain
yet.
Hallo Lindsay,
look like there is no iron involved to the core of the coil!? It seems to be important, or not?
greetings
Norbert K??ner
