The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 27 Guests are viewing this topic.
hartiberlin
Hi Dave, you might be right in the case of a real grounded device, but the TPU is not grounded at all, so the placing of the transistor should not play a big role....
gn0stik
Marco, caps is a good approach, as you need a fast sendoff, and fast SHUTOFF. That is the action that creates the bunching effect, and in turn creates the kicks.
hartiberlin
Gnostik, you are right, pulsing a coil with multiple pulses will give a curious high power RF burst in it, as you can see with the Newman coils, when the commutator makes multiple very short breaking contacts from the battery to the Newman coil. There you have the same effect of immense radiation around the coil. Steven Mark seems to capture this radiation capacitively!
hartiberlin
P.S. In the Newman machines the radiation is lost, cause it is radiated away from the coil. if we would wire around the Newman coilwire perpendicular another wire and use this combination to build  a Newman coil, one could probably get very nice power out of it !
gn0stik
Quote from: hartiberlin on September 22, 2006, 03:27:01 PM
I'm not familiar with the newman machines. But capturing the radiant is the key to many of these machines. See gray's tube device that he used to capture the radiant after he split the positive.
