The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 37 Guests are viewing this topic.
gn0stik
OK, first,
RE: my last post about being able to measure kicks. If the kicks are of a radiant nature, we probably won't be able to measure them with normal equipment. However, I know that we will be able to measure something interesting.  To quote SM
It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another. Then you can measure all kinds of things going on. You can generate all kinds of hash and multiple frequencies, and I do mean all kinds.
So, what we need to figure out is what we are looking at.... or for.. What is the "all kinds of things going on"
Also, I could be dead wrong on this. It could be straigt up power. If that is the case, just creating superposition of frequencies will generate nothing. We need the lightening quick PULSES. Fast on, fast off. And LOTS of them in succession.
I spoke with Peter Lindemann on the phone a while back, he told me that in Tesla's experiments what tesla found is that when current suddenly stops in a wire, Potential(voltage) will make a path, in the sudden absence of current, it will rise dramatically and CREATE CURRENT FOR ITSELF. He said something like 10,000 volts is roughly equivalent to 1 Amp of current, by our present day measuring system. Which seems to me to be extremely unbalanced if in fact current and voltage have equivalnces. He also explained how the inverse can happen..
Now, the second purpose of this post..
Remember how I said I'd go check out amasci.com again, and bill beatty's stuff and do some research on magnetometers?
Well Amasci.com did it again. Bill Beaty amazed me. I found a PDF of a design for a magnetometer there and some technical descriptions of how they work... Very interesting read. There are also some diagrams of some coils that actually look a bit like a TPU in other articles.
At any rate after reading the attached article, I'm sure we'll be talking about things like proton precession, and playing with a few new frequencies, and winding coils with specific numbers of turns, and tuning circuits. It will need to be adapted a bit to what we are doing, but so much of whats in it is relevent it's rediculous. The specific Magnetometer in the article is made with detectors that utilize distilled water for it's hydrogen content, but that's not the only kind of magnetometer out there. Like I said some of them have very similar coil designs.
It explains the magnets, it explains frequencies, and how to find the ones we want to play with, it explains pulsing the coil, and why it's important for the current to abruptly stop... It's actually kind of scary.
For those of you who don't know what a Magnetometer is, it's a device that detects and converts the earths magnetic field into small amounts of electricity, for the purposes of scientific research, and detecting metal..
You see a magnetometer is resonant with the earths magnetic field, and when the earth's magnetic field is perturbed by a local magnetic field electron polarities change and it induces a small current in the device, which is used for a sensor and trips a circuit to let you know about it. (in the case of magnetometers that are used for metal detecting).
Now what could be the perturbing local magnetic field that triggers this reaction in the TPU? Hmmm?
Regards,
Rich
supersam
rich,
did you not hear, compression of electrical field can also create a power surge!  a rapid increase in voltage like you can get out of a toroidal coil "transformer" can also create a power surge.
i guess, it all depends on how you ramp your coil up: or switch it.
the point being there is more than one way to skin the cat.
lol
sam
supersam
rich
ps i think it all depends on how you use your contol windings.  you can use them to step up the voltage with a loss of currrent if you want to.  maybe even to the point you get a "kick". this is actually a little more than theory.
lol
sam
gn0stik
Quote from: supersam on September 29, 2006, 04:42:06 PM
rich,
lol
sam
I hear what you are saying Sam, and I agree for the most part. However, I believe there is only one way, conceptually to skin THIS cat. New technology is usually created by joining two or more older technologies together. The wheel, and the shoe for example, make rollerskates, and people have been enjoying them for quite a while now. How long had the wheel and the shoe been around separately before some guy in the 50's or 60's in California decided to put them together? Centuries? Millenia? That's just an example. Convergence of technologies can be extremely powerful, as in the example of the convergence of the bicycle, kite, and internal combustion engine, by the wright brothers.
The basic components of what we are making will be simple, and known quantities, and when we get it together, we will all say "OF COURSE, IT'S SO SIMPLE!", but for now, it's baffling. SM claims his device is simple, that it uses the earth's magnetic field, and that it uses kicks of energy in specially wound coils, that it requires sharp on and off pulses of power to create the kicks, and that it's started by a magnet. So, with that description, what existing technologies can we explore that exhibit some or all of those properties? Tesla's work, Antennas, and Magnetometers. I'm not saying this is absolutely correct, but a convergence of those three things would indeed manifest a device very similar SM's device. As to compressing an electric field.. yes, we know about that. We've studied the "bunching effect" extensively, and it's a direct extraction from tesla's work.
However, I've never seen a kick come out of a transformer in normal operation. Dave is working with htrs slightly out of phase with eachother right now, and I assume he's connecting them in reverse of one another to see "all kinds of things going on."
Rich
giantkiller
All well and good....
But the toroid has an emmission face that points inward towards itself, the center. And that is where the compression comes in.
When you apply a square wave, on the front side of the pulse the magnetic field ramps up, but on the trailing edge, the force slams back to normality exceedingly faster than the up start due to not only the earth's magnetic force but the magnetic force of the compression. Huge back-emp. On the scope you see the current pulse as that happens. Nature abhors a vaccum.
That is the 'Kick', and the harmonic buzzing and the gyroscope leveling effect. Plus the fact that the first lines of flux generated break apart from the center and envelope the unit spherically, more potential built up. Again, on the trailing edge these outer flux lines break, unleashing more power, back to enveloping the toroid and decease through the windings. A sine wave can't produce this effect as great.
It slowly relaxes and looks like the generated freqency. But again, the square wave has infinitely more frequencies and harmonics. All this work is very dependent on how the unit impresses force and vibration to create interference against the earth's magnetic field. Tesla talked about this. 8)
