Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
Omnibus
@X00013,
I got it. To get rid of the background sheet just un-check in View the buttons for Background and Working (not intuitive). Then proceed in SolidEdge as if mm are meter and orient everything w/ respect to the zero of the coordinate system. Thus, when you import the created dxf in wm2d the new sketch will be positioned properly w/ respect to the earlier sketch (which is also drawn with respect to the zero of the coordinate system). This whole thing makes a lot easier the drawing and the import of the various details into wm2d. Now will have to figure out what the for of the track should be.
Jubjub
Due to the site being down for maintenance yesterday I was unable to upload anything until today.
Here's the link for the video of my rough version -> http://www.youtube.com/watch?v=3skVetNsbZY
As for the Max-file you'll have to wait until I get home from work (Yes, I'm at work right now...)
AquariuZ
Quote from: Jubjub on April 30, 2009, 03:19:28 AM
Most impressive!!! :o
AZ
AquariuZ
Quote from: ruggero on April 29, 2009, 10:29:30 AM
I know...this is an old post from AquariuZ â€" but I think I have found something new and interesting:
What you call a "barrier", that I believe is actually a "Shooting" mechanism.
The whole guide tuns like a pendulum when a weight fall at 04:00, and push the "Shooter" to the left.
When the weight reach "weightlesness" around 09:00, the pendulum guide falls back....and the "Shooter" fire.
How does that look...?
ruggero ;-)
Ruggero, YES COULD BE
It is so sad I do not have a decent 3D modeling program nor the CPU cycles to correctly model...
Frustrating...
AZ
AquariuZ
Jubjub, what software is this? And is there a free or demo version I can abuse? I wish to understand if this has accurate gravity modeling in it.
Also:in the patent or like dustys design the grooves are offset and do NOT point to the center axle... Other than that: full marks.
AZ
