Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
i_ron
Quote from: noonespecial on April 13, 2009, 12:24:44 PM
Hi Ron,
I was just keying off of his comment that the weights are alledgedly "moving faster than the system".  Again, if what you say is true, then in my opinion this is nothing more than yet another unproven overbalanced wheel assuming there is nothing unique to this design.
Charlie
Hi Charlie,
Yes, but the point at which the weights are moving faster than the system is not stated. It is my contention that they are, but after the constriction.
To me, that hook at the end of the slot is the key to the wheel. This is what makes the wheel work. I have been searching for a proper name for this effect that he is using and while it is the most basic mechanical motion it is used so very infrequently. The only analogy that comes to mind is working in a hydraulic press. The “action” we are talking about is not wanted. The two planes are required to absolutely parallel. If one plane is the slightest out of parallel then the forces are not transmitted perpendicular and disaster strikes… the work is propelled out of the press with extreme velocity.
So the weights are in two states, the outer weights at high velocity and the inner  weights at a slower velocity, as they are describing a smaller radius. If, as in previous wheels, the weighs are just feed back into the high velocity circuit they will take energy from the wheel to bring them up to speed. That is why we have never seen a working wheel before. This is why all the syms show a “semi” balanced wheel…. one must factor in the squeeze.
Take a greasy cherry pit between the thumb and bent finger… yes?  It goes a long way, does it not?  This is, or must be, the final action as the slow moving weight is feed back into the high velocity circuit… to give it a little squeeze and spit it back into the higher velocity circuit at speed.
And you might ask… where is this in the computer models?
Ron
noonespecial
Quote from: AB Hammer on April 13, 2009, 01:13:35 PM
Greetings Charlie
That is one of the reasons I posted one of my old designs. For if the Sjack Abeling Gravity Wheel, would work. Mine would as well. IMO Here is the link to my string with some written improvements for it, if someone wanted to build it. It was on my list to build one day when I didn't have a better design to try. So why not post it on its own string. I feel it has a better than average chance but the average of the over balanced wheel stinks. LOL
http://www.overunity.com/index.php?topic=7235.0;topicseen
Don't get me wrong, I am interested in how the Sjack Abeling gravity wheel truly comes out, and I hope for the best. But I am not good at simulations either, so I can't be of much help in that field.
Hi AB,
Good to talk to you again! I did look at your design and quite frankly, I would think that yours has a better chance of working than Sjack's. I would encourage you to build one. And while we are on the subject of builds, here's a shameless self-promotion of my latest one: http://www.youtube.com/watch?v=1uKoAwFFwPY
Like you, I am interested in Sjack's design but I won't hold my breath waiting for a press release. At least Bob Kostoff provided a video of his design working. Although, he seems to have been spirited away by the MIB :).
Anyway, I'll keep watching...maybe we'll be pleasantly surprised someday.
Best,
Charlie
rbe
Hi all,
Just a few questions that popped in to mind. Has anyone thought of the actual dumbell design and might it be essential to make the wheel work as stated by the patent.
* Will the dumbell's spin in a (counter?)clockwise motion to create some extra down force when they are "shot way" at the top position and then land in the end of the slot?
* Are the dumbell's equipped with... for example ceramic ball bearings to make it extra slippery when its in the "scissor" part of the wheel, to make it more like a cherry pip like Ron describes.
Perhaps this has no real relevance for the wheel performance, just some thoughts.
Cheers
noonespecial
Quote from: i_ron on April 13, 2009, 01:38:49 PM
Hi Charlie,
Ron
Hi Ron,
I do understand your point. However, in both of your examples (hydraulic press and cherry pit) external force is applied first. This force isn't free and is in fact, directly proportional to the projectile energy produced. Squeeze the cherry pit a little and it only goes a little way. Squeeze it harder and it travels farther. There's no magical additional energy produced from this interaction. If you can show that there is, I would be very interested.
Regards,
Charlie
AquariuZ
Initial try own wheel and guides, cherrymans egg and a modified cherryman barrier.
Initial speed given to wheel around -0.100 rad/s
It will turn without motor for a loooong time (until wm2d limits)
Not being able to reproduce results from yesterday, but that´s prrobably because there is no true "launching" going on..
Model attached
