Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
AquariuZ
Quote from: mondrasek on April 14, 2009, 04:19:22 PM
Could be, but what if it does truncate?  If it is just keeping the four significant digits that are shown (truncating any further digits calculated) then using very large and small numbers together will mean that the small may have zero effect on the large.  Not a small effect as would be correct, but zero.
This may or may not be something to watch out for.  But when you look at the mass of the 320 M diameter wheel and compare that to the mass of the weight balls in some of the earlier sims and you may see the concern.  Keeping everything in the same logical range only helps to avoid this possible issue.
You are right ofcourse, Cheryman is still punching out 300 meter diameter wheels.
That would draw some attention from the neighbours, huh.
Cherryman
Quote from: AquariuZ on April 14, 2009, 04:22:43 PM
Uw e-mailkenmerk is 235676.
Geachte heer,
Naar aanleiding van uw e-mail, waarin u vraagt of Abeling Beheer B.V. toestemming heeft van het ministerie van VROM voor de bouw van Gewicht Energie Centrales in Nederland, kunnen wij u als volgt informeren.
Helaas kunnen wij uw vraag niet beantwoorden. Uw e-mail hebben wij daarom voor verdere beantwoording doorgestuurd naar het ministerie van VROM. Om uw vraag goed te kunnen beantwoorden, is het mogelijk dat de beantwoordingtermijn langer is dan de eerder aangegeven twee werkdagen.
Wij hopen dat u hier begrip voor heeft.
Met vriendelijke groet,
Danny Huf
Publieksvoorlichter Postbus 51 Informatiedienst
TRANSLATION
Your e-mail reference is 235676.
Dear mr,
Further to your e-mail, in which you asked whether Abeling Beheer BV has obtained permission of the Ministry of VROM for the construction of Weight Power Plants in the Netherlands, we can inform you as follows.
Unfortunately we can not answer your question. Your e-mail has been forwarded to the Ministry of VROM for further response .It may be possible that the response time is longer than the regular two days.
We hope for your understanding.
Best regards,
Danny Huf
Public Information Officer PO Box 51
Waiting then. (not holding breath)
Good work!
And the story continues...    It's becoming a "thriller"   ;D
Now hope you did not wake up a sleepy government official, who suddenly sees that a lower offical has granded the permission...  now he gets youre request... realisez he impact and calls the MIB..  Poor Sjack..   :o
;D
Cherryman
Quote from: AquariuZ on April 14, 2009, 04:26:34 PM
Size does matter!   ;D
But i will try to think of rescaling..  The strange thing is that i design in .mm , so somewhere in the conversion from Rhino to DXF there must be an upscaling..
My workflow does'n t like scaling. I like the design in Rhino to be an exact copy of the Design in WM2D, so i can adjust or add easaly and quickly new parts.
But for the sake of free energie i will try to not forget scaling.
spinner
TRANSLATION
Sir,
Best regards,
Danny Huf
Thanks for your translation!
I'm not holding my breath, either.  :(  It seems that at least the guy which answered your e-mail doesn't know anything about the Abeling ...
Cheers!
"Ex nihilo nihil"
rlortie
Quote from: mondrasek on April 14, 2009, 03:35:42 PM
I'm not thrilled with calling CF "not a true force", but I have seen it expressed as that, or as a "fictional force".
Lets try this example.  You are driving straight in your car.  If we remove all friction you will continue in a straight line forever.  When you initiate a turn by turning the steering wheel, you feel CF, right?  It pushes you away from the way you want to turn.  But what is really happening is your body is trying to continue in a straight line.  There is no force pushing on you.  So CF is fictitious.  What you notice is the change in direction of your reference frame which is the car.  It turns due to a force, but your body does not want to.  What you are experiencing is a resistance to a change in direction due to a force.
I agree it is very confusing to use those terms.  But it might also be more confusing for the term Centrifugal Force to have ever been used in the first place.  Maybe it should have been the Centrifugal Sensation?
I am from the old school!  CF a fictional force and I shall attempt my explanation as to IMO.
When you are traveling in a straight line, kinetic induced inertia tend to keep the trajectory in a straight path. When you turn the wheel, you are not being "pushed" by CF , but rather pulled by inertia wishing you to stay on a straight path.
Shoot an arrow straight up, ask yourself what roll does CF portray when the arrow runs out of inertia? There is no CF, the arrow stops and then starts it path back to the ground.
A lot of researchers have tried to utilize CF as a means to accelerate a gravity driven device. Plain and simply put there is no CF without inertial acceleration, and a physical CpF containment to keep it radial.
Ralph Lortie
