New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
overtaker
Alex, just make a trip to your local tackle store. The weights are already 1,2,3,4,5,6 oz. with a hole
for attachment.
Alexioco
Quote from: Low-Q on April 17, 2009, 03:39:34 PM
That is the exactly point in conservation. Conservation means no change. No change means no work.
If gravity was dynamic, however, like it increased and reduced all the time, it would do work, but that isn't the case in real life.
So bottom line; A conservative force like gravity cannot do work, are not capable to do work, and will never do work.
Vidar
I dont agree because though gravity is constant, weights that move in and out of an axle are not, a weight with gravity equals force and that force can be made greater or lesser depending on the position of the weight to the axle of rotation...
Wind is dynamic but even if it wasnt, it could still turn a wheel due to the blades, so that same effect needs to be applied to gravity so that its pull is stronger on one side of a wheel than another but this time, not by blades, but by weights...
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Quote from: overtaker on April 17, 2009, 04:08:28 PM
for attachment.
Ok I have some weights, they are fantastic too because they are spherical weights so I can use them for other designs, even with rolling weights, I bought them from a tackle shop, thanks for that overtaker...
All I need to do now is make the levers, attach the weights, then I'm done, I will post it on here weather working or not...
noonespecial
Sounds great Alex!
Looking forward to your results.
Regards,
Charlie
Alexioco
whooo I'm getting there now, I have cut half the levers out ( 8 ) just need to cut another 8 out then I am done...
Reason for a total of 16 levers is, I put two levers together with the weight inbetween them, so when thats done, I will have 8 weighted levers ready to be fixed into their positions in the wheel, and its ready to gooo
see you soon
Alex
