HHO explosion slowing down the burn speed of HHO to get compatible with gasoline
Started by hartiberlin, April 18, 2009, 05:19:02 PM
hartiberlin
Hi Les Banki,
many thanks for the additional infos.
Your circuits are now also posted over here:
http://www.overunity.com/index.php?topic=7287.0
User Woodpecker also has a working motor running just on HHO, not yet selflooping ,
but probably soon.
There is much progress lately with all the HHO designs.
I guess this year someone will show a selfrunning HHO-Motor-Generator  combination outputing electrical excess energy
and only needing water to run it.
Regards, Stefan.
4Tesla
Quote from: Les Banki on April 21, 2009, 03:10:58 AM
Simple
It was/is no big deal!
We just held the gas nozzle (0.6mm diameter orifice) at the air intake.
Several people were present, assisting and video taping the experiments.
We did NOT modify the engine in any way, NOR did we adjust the ignition timing (inaccessible behind the flywheel)
The engine was only idling since the very, VERY inefficient  "brute force" electrolyser I had at the time could not produce enough hydroxy for higher rev.
These experiments were conducted mainly to disprove all nay-sayers, claiming that an engine could not run on hydroxy ONLY.
For anyone who might be interested:
Since then, I have developed/designed a complete set of ignition circuits for one cylinder engines in order to completely ELIMINATE the 'waste spark'.
I have also written detailed circuit descriptions and a couple of articles about the ignition system in general, explaining what is required for proper operation of an engine running on HYDROXY ONLY.
All that is available, FREE, at:  waterfuelforall.com Forum
If you sign up and log in, you can access ALL files.  Circuit diagrams, pcb layouts, circuit descriptions and general articles I have written on the HHO subject.
Best regards,
Les Banki
Thanks so much.. now if we can just have a module for cars like this one for E85:
http://www.fuelflexint.com/pages/product1.htm
along with the electrolyzer.  If you made these kits, I would love to be a distributor!
Tesla
d3adp00l
Ya stephan, I think I have a bit of experience in running hho in an engine. And running it in an engine designed for other fuels is pretty much a waste of time.
You guys need to stop thinking of hydrogen as then fuel. Do some research into the properties involved and see what direction it takes you.
Skip this interm step leap frog off what others have done. The flame speed really is not all that important. The shockwave energy in conjuction with thermal to mechanical energy conversion is an aspect to think on.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
d3adp00l
-Carl Sagan
hartiberlin
Hi d3adp00l,
we need just one guy getting a HHO generator produce enough gas to run a generator
and have the generator output looped back to the HHO Generator to produce the HHO gas
in a selfrunning mode.
It does not matter, if this system will on the longer run destroy my generator via
hydrogen going into the cylinder or cylinder heads.
Important is just a demonstration that shows, that it is possible this way to run
the whole system solely from water and no other
external power. That is the whole point to demonstrate this without any doubt
and this have a selfrunning overunity system that is just powered by cheap water.
Then engines can be made, that will not go bad from the shockwaves or
the hydrogen going into the metal.
Regards, Stefan.
