Thanks to ALL for your help!!
Maxinum utilization or Back EMF...?
Started by the_big_m_in_ok, April 19, 2009, 01:30:47 PM
the_big_m_in_ok
To generate very large amounts of electrical power with a modest initial input source, try this as an experiment?
1) Build a simple push-pull occillator out of, say 2N2222's and, say, a 30-35 VA transformer from Radio Shack or the equivalant.  Use as the occillator power source: a 1.5 VDC battery.
2) The transformer, wired backwards with the occillator going to the secondary, steps up the output from the ocillator from about 1.5 VAC to 12 VAC on the primary (mains) coil.  Take a long wire and loop several turns around this transformer to a much larger, or set of, transformer(s), thus using the occillator transformer as a trigger coil for the Back EMF to the whole bank.  Rectify the output of this bank to charge up a bank of batteries similar to the first one.  This bank can be wired in series or parallel---or both---as required.
3) Take 1.5 VDC from the large output bank and run the occillator with that power so that the system is self-generating indefinitely.  (The positive side of the battery can be reduced in voltage with a resistor, if necessary.) The excess power is used to run whatever you like.
There's a thread on Overunity that illistrates this idea very well that's entitled:  "Milliamps in, many amps out!"  Unfortunately, my time is limited on this borrowed computer, or I'd look for it.  There's a drawing of the schematic on the paged reply.  It tells the whole story with one picture.
NOTE:
The large bank will probably send strong power spikes through the trigger main coil to the secondary, thus stressing the @2N2222's with considerable power surges.  In that case, wire one or more diodes, even including properly valued zeners, to the positive terminal(s) of the output bank, thus harvesting the conducted Back EMF from this source as well.
--Lee
the_big_m_in_ok
Low-Q
Quote from: the_big_m_in_ok on April 19, 2009, 01:30:47 PM
NOTE:
--Lee
the_big_m_in_ok
Drawings?
the_big_m_in_ok
Quote from: Low-Q on April 22, 2009, 07:01:35 PM
Drawings?
>>Yes, thank you for asking.  I do have a schematic for an experimental test system, but I can't upload it without a scanner on this computer.  I can try on another computer as a software experiment at a local junior college, which does have a scanner.  (The drawing needs work, but it's ready now.  Some explaination(s) may also be necessary after uploading it.)
--Lee
Cap-Z-ro
Can't seem to locate that 'Milliamps in, many amps out!' thread bigM.
Are you sure the thread title is correct ?
I must have missed it first time around.
Regards...
the_big_m_in_ok
Cap-Z-ro said:
Can't seem to locate that 'Milliamps in, many amps out!' thread bigM.  Are you sure the thread title is correct ?  I must have missed it first time around.
Regards...
>>I made a copy of the data picture file, and now I can't find it in my notes! Frustrating!
You might have a point?!?!
I just can't prove it.   >:(     ???     ::)     :-\
That was the title I remember.  A small ocillator was paralleled onto a larger coil and that trigger occillator caused a power surge with Back EMF to be harvested with a full wave bridge.  Really.  Simple and easy to prove, the way the posting Member drew it.
Well, I'll have more time to try and find it tomorrow, if I can find it.   :(
I'll also try and upload my schematic.  On a borrowed computer.    :-\
--Lee
