Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
Grumpy
Quote from: gravityblock on May 01, 2009, 05:05:00 AM
Only one kind of photon.  The photon makes up the entire electromagnetic spectrum from radio waves to gamma rays.  Photons are delivered in packets or quanta.  Higher frequency photons can be delivered faster than lower frequency photons.  The higher frequency photons travel the same distance as lower frequency photons in a given amount of time, but they travel more space in the same amount of given time.  This is due to their wavelength.
Try to visualize a photon propagating through space in a corkscrew motion.  The shorter wavelengths will have a tighter corkscrew motion and is making more turns per revolutions than the longer wavelength photons, thus traveling the same distance but traveling more space in a given amount of time than a longer wavelength photon.
A photon that propagates through space in a straight line instead of a corkscrew motion would have a near zero wavelength and could be delivered in a continuous stream instead of packets, thus traveling faster than the speed of light.  In my opinion, this is the virtual photons and virtual particles that physics theorize about.
Try to think of a led light blinking.  The slower it blinks, the longer the wavelength is. This would represent a photon with a longer wavelength.  The faster it blinks, the shorter the wavelength is.  If the light is continuously on with no blinking, then it would have a zero to near zero wavelength and this would represent the virtual photon that physics theorize for the magnetic field of flux.
This is the reason why the magnetic field of flux is not changing in a magnet (the virtual photons are being delivered in a continuous stream and cutting the flow of electrons), thus we have to move the magnet or conductor in order to cause electrons to flow along a conductor.
If the virtual photons were delivered in packets in the magnetic field of flux, then we would have a changing magnetic field of flux and wouldn't need to move the magnet or conductor for electron flow and would have OU very easily.
It appears to me that the entire universe is a sea of these virtual particles, which I say is the aether.
Most of this is currently accepted in physics as being correct, but some of this is my own personal theory.
What do you think about this theory of mine?
It is very curious that some of what you write here, I recently sent to others in private messages.
Photons and electrons do not have to travel to produce a current.  Google "polarization current".  Positrons can also cause a current, but everyone forgets about them.
Anyway, GB, I agree that the aether is a sea of what others consider to be virtual photons - or "spin centers" if reading Wilbert Smith's explanation.
Photons are a subject of intense research these days.
        -Frank Edwards
gravityblock
Quote from: allcanadian on May 01, 2009, 09:08:44 AM
@Gratityblock
-----"Knowledge is understanding what is true and what is not true"
I would state this in a different manner, I know many people who can retain a great deal of information and we consider them very knowledgable, that is having knowledge of many things. However, possessing a great deal of knowledge does not imply in any way that they truely understand the knowledge they have retained because knowledge is information which can be true or false depending on perspective. Understanding is knowing the difference between what is real and what is not and usually involves the practical application or proving of knowledge. In any case, I have found "knowledge" and "understanding" to be two very different things, as one person said "you cannot build what you do not understand", this is a truth I believe everyone can agree on.
AC
Not me.  I have built electronic circuits that I did not understand by following instructions from someone who had the knowledge.  I could list many things that I have built without understanding how they fully worked.
Have you ever thought you understood something and then later found out, that your understanding was wrong?  If this was the case, then you didn't have the knowledge of that something while your understanding was wrong.
I'm sure you could find a way to prove the point you're trying to make that would be in contrast with what I have said.  I'm through with this discussion also.
gravityblock
IotaYodi
"The popular conception of electro-magnetic energy transmission as it exists today is; energy is transmitted through the interior of the conductor material, that is, electricity flows through wires like water flows through pipes. This transmission is said to involve the flow of charged sub-atomic particles called electrons."
Not by what Ive seen Electrical engineers say. The electrons,or whatever name you want to put on it,travels basically on the surface. If the force is increased on the same size conductor,it starts to flow further inside the conductor which starts to heat the conductor because of more opposition to the flow. This is why higher current carrying wires are stranded because there is more surface area and less resistance.
A simple anaology would be a garden hose spraying down a driveway compared to spraying the ground. More feedback on the driveway than the ground.
"Conversely, free space devoid of matter offers total opposition to the flow of electricity. Nothing could be further from the truth, yet this is the concept of electricity propounded by the scientist of today"
A misleading statement and play on words. Free space is not devoid of matter and they know it.
What I know I know!
Its what I don't know that's a problem!
Magnethos
The explanation of Marco is EXCELLENT!!!
After reading about similar subjects and authors, I have got the same conclusion as him. Real electrical current is Cold Electricity, and not Transverse ElectroMagnetic waves. The EM energy is an unnatural, retarded form of electrical energy.
Conventional sciences looks at the EM energy instead of Cold Electricity. The key is all the universe has an extremely high amount of this "cold electrical current" (massless energy, displacement energy, etc...).
This Cold Energy is based on sub-electronic particles. I mean, the pure potential waves has a very known kind of electrical particle called "Neutrino, Tachyon...", instead of the electron.
When you switch on a circuit, there is radiant energy flowing through there. After a period of time, electrons start to flow in the circuit and then you can measure voltage and amperage. This happens after a very short time (depending the material of the wire, and other characteristics), called The Relaxation time in conductors. You can extract ampere-free energy from ANY energy source. The only thing that kills the battery is the amperage extracted. If you extract pure potential waves (electrostatic energy), the ambient will replenish all the voltage, but not a single drop of ampere.
Static electrical current is present everywhere in the space-time, so we can extract unlimited amounts of electrical energy anywhere and anytime. That just what Tesla tried to show us.
I will made a section explaining better this.
