Latest: No back torque generator.
Started by broli, May 01, 2009, 09:04:43 AM
gravityblock
Quote from: BWS on May 15, 2009, 02:06:09 PM
@gravityblock
well ok, please let me clarify:
Yes of course the wind is moving in a tornado, but the wind does not represent the magnetic field there, the wind is moving relative to (perpendicular to the B field causing it's induction/circulation) the B Field which is along the vertical axis of the tornado.
-BWS
Planes fly in the eye of a hurricane because it is so calm on the inside.  B Field lines always form closed loops.  The closed loops can easily be seen in the circular spin of the wind.  The B Field lines must not have a start or end point. The inside of a cyclotron can not represent the B Field cause there is no force there.
I'm going to say this and say it only once.  God told me that the magnetic field or flux moves with the magnet.  Go debate this with him, he offered no explanation to me why this is.  I'm just trying to explain or understand this with the limited knowledge I have.
BWS
@gravityblock,
I'm hesitant to reply, so you can tell me to shut up and I will, but you've raised a great point about airplanes...  The center of a hurricane would have a very large and very uniform magnetic field.  The magnetic field is not force, only potential force needing the right circumstances (available reactive material which is usually other magnetic material).  It is my belief that (similar to what EE's believe) a gradient of field is needed for there to be interaction.  Since there is no focused source of the giant uniform field, there will be no net effect on the plane or anything in it.
  Does moving a field include rotating a field?
-BWS
gravityblock
Quote from: BWS on May 15, 2009, 02:52:07 PM
@gravityblock,
-BWS
There appears to be a potential force where the winds are spinning. Maybe you should fly the plane there and see if the uniform field is a focused source or not.  After doing this, you may learn where the field is actually located.
lumen
Well as for the test!
I used a stationary 3" dia. ring magnet and a .125 thick steel disk and by spinning only a single wire as a conductor to the edge of the magnet it is obvious that it does generate current.
I also tested spinning the magnet and tried to obtain a current flow by trying to shield the return line with another magnet. This setup was unable to produce any output!
I made a small video so anyone can see the results of this test.
http://www.youtube.com/watch?v=XSWwrvT_c8w
Quote from: lumen on May 15, 2009, 03:50:43 PM
That's a cool setup you've got there I wish I had something like that. But can you make some illustration of the two different setups because it's not very clear from the video.
Edit: nvm the hq version made everything clear. I'll think about something to say now.
