Thanks to ALL for your help!!
Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
baroutologos
Thank you very much I_ron for the lively presentation of what happens between a magnet and  a coil!
Ok i am not that noob. I know the basics. I just wanted to know your findings regarding the discrepancies observed between a shorted coil and a loaded coil in "Perepiteia" mode.
It seems like we deal with some kind of mystery, yet.
Apart form voltage creation. When coil is shorted a smooth, Lenzless, action is present.
When loaded, this smoothness goes away, drag manifests that is proportional to real load applied and have to pay each watt out.
Reasons still unknown for that. Neither coil's turns help to offset this from happening.
Anyway, thanks again
Regards,
Baroutologos
CRANKYpants
Quote from: i_ron on August 21, 2009, 11:12:39 PM
Now contrast that with the erroneous statement made earlier by the inventor…
Can you see the discrepancy? What I have stated can be verified, by you or anyone. It is common sense. It just IS. You don’t need a scope… just an analog meter will do, connect your meter to the coil/core lying on the bench and rapidly move a neo up to it. The meter will give a blip and stop when you stop. Zero motion equals zero induced voltage. Now pull the neo quickly away from the coil/core and you should see a blip in the opposite direction. Exactly as I have stated.
I will let Thane have the final word…
Regards, Ron
THERE CAN NEVER BE ANY "REAL" FINAL WORD WHEN DEALING WITH A CLOSED MIND.
QuoteZero motion equals zero induced voltage
THIS CORRECT INFORMATION - IT JUST DOES NOT APPLY IN ANT WAY AT ALL - IT IS LIKE A GRADE 1 STUDENT TRYING TO EXPLAIN - QUANTUM PHYSICS - YOU ONLY GET TINY FRACTION OF THE WHOLE STORY.
NOW REPEAT YOUR EXPERIMENT WITH:
1) A SHORTED HIGH VOLTAGE COIL
2) ABOVE THE CRITICAL FREQUENCY
3) SUCH THAT THE INDUCED VOLTAGE IS STORED IN THE COIL'S PARASITIC CAPACITANCE
4) BECAUSE THE COIL'S IMPEDANCE DOES NOT ALLOW CURRENT TO FLOW.
A CORRECT EVALUATION IS BOTH ABOVE YOUR UNDERSTANDING AND DESIRE - IN FACT IF YOU TRULY HAD THE DESIRE (AND AN OPEN MIND) THE UNDERSTANDING WOULD EVENTUALLY FOLLOW - THAT IS METAPHYSICS - SOMETHING ELSE YOU CLEARLY DON'T UNDERSTAND EITHER.
THAT'S MY "NOT SO-FINAL" FINAL WORD.
T
i_ron
Quote from: baroutologos on August 22, 2009, 05:07:54 AM
Regards,
Baroutologos
Baroutologos,
Yes, I have followed your work and know you have a good understanding.
My little little "coil/magnet 101" was for the many on the list that seem to be a bit unclear as to what is happening and let statements, like my quote, go unchallenged.
Keep up the good work,
Ron
i_ron
Quote from: supermuble on August 22, 2009, 01:48:39 AM
I have a few questions.
You did not talk about current in this explanation at all. Current is what makes the magnetic field, not voltage, right?
Your explanation at the end makes no sense whatsoever, at least not to me. No offense. How can the external field be reduced, and core drag reduced, and then Lenz's law drag INCREASED. I don't understand what you are trying to say.
If you short a coil, you have a stronger external field, and stronger magnetic drag because of Lenz's law. It's pretty simple.
Super,
It is a complex reaction taking place and you are quite correct, current flow is of prime importance. But in the interests of laying a basic ground work that we could build on I kept the explanation as simple as possible. As you know, voltage is a first necessity, first you have voltage, then current can flow.
I felt comfortable in leaving out current as I had already posted the resultant flux field between a shorted and unshorted coil previously.
This confirms what I said, that the field reverses and is reduced at the same time, for a shorted coil.
I did the experiment one time also with a single HV shorted coil with a sense coil winding over top of the HV winding. The external field is/was
practically nonexistent.  Just do the experiment. I will accept different results as long as the conditions are stated.
Two and three were answers to separate questions, are you running them together?
Ron
CRANKYpants
@ ALL,
I-RON HAS HIS OWN THREAD NOW - FOR HIS DISCUSSION AND TEST DATA.
ANY POST NOT PERTAINING DIRECTLY TO REPLICATION OF THE GENERATOR OR TRANSFORMER WILL BE REMOVED MONDAY. TO PRESERVE THEM I SUGGEST CUTTING AND PASTING.
T
