0 Members and 115 Guests are viewing this topic.
stivep
Spark Gap tubes evaluation for project.swf
http://www.youtube.com/watch?v=WDcITQ7gtaI
and in addition to that:
consideration of ultra fast spark gap switching
http://rfierro.ecen.ceat.okstate.edu/summa/notes/SwN/SwN28.pdf
Abstract:
Geometric considerations for ultrafast spark gap switching
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=829645
Micromachined Planar Triggered Spark Gap Switchhttp://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=5975207
http://home.earthlink.net/~drestinblack/sparkgap.htm
Electrodynamic simulations of a photoconductively switched high voltage spark gap
http://iopscience.iop.org/0022-3727/38/16/009;jsessionid=54C8E3378702F34F6587565127DDC051.c3
A new design concept for field distortion trigger spark gaps
http://jap.aip.org/resource/1/japiau/v57/i7/p2507_s1?isAuthorized=no
A common field distortion triggered spark gap utilizing geometric field enhancement at sharp edges usually operates in a cascade mode via the trigger electrode. A new trigger concept is proposed allowing strong field enhancement and direct breakdown between the two main electrodes. A test setup was designed to prove the feasibility of this concept. Experimental results on delay and jitter depending on percent breakdown voltage are presented. Best results achieved are a delay of 9 ns and a jitter of 2 ns at a self‐breakdown voltage of 15 kV.
This one is good
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=
0CGIQFjAH&url=
http%3A%2F%2Fwww.kps.or.kr%2Fhome%2Fkor%2Fjournal%2Flibrary%2Fdownload
Pdf.asp%3Farticleuid%3D%257B20EB858D-1A4D-4903-8BF1-113BCB3934A4%257D&ei=xsocT7-UF-HY0QGi6ZmCAw&usg=AFQjCNFFS3Zf96so8-ibAjTK5-99rXWfkQ&sig2=
nLFMH7gI3tOpPJjrY6ZeDQ
I want to bring to your attention this article and video link
http://www.coe.ufrj.br/~acmq/svanberg.html
http://www.youtube.com/watch?v=5oGSWzkXhs0&feature=player_embedded
You building charge from  ZERO.
If it is automated mechanism by means of pulse that might be the secret  leading to FE.
All of requirements.
Charge from ground, body,
capacitive coupling
buildup of electrostatic charge
compare it to
Abramienko fork - one wire  supply.
Based on Glen with approval of Dick from scientific group of mine there is never one wire  circuit
so closing of circuit is done by electrostatic coupling means and/or electromagnetic.
but for electromagnetic we need rectifier( detector)
-unless we dealing with electromagnetic direct line of flux coupling
example: electromagnetic wave send  for the distance of 1KM has no direct lines of direct flux it is radiating wavelength that resonates in the receiver antenna.
for electrostatic we do not !!!
Just try to think and help each other
by contributing to that statement.
Wesley
wattsup
@stivep
WOW, WOW and WOW again. I asked for a mole hill and you gave me a mountain. Incredible video with so much discussion of these spark gaps and the traps we have to try and avoid. I just wrote to a manufacturer of simple sparks gaps asking for some pricing information and one of the models was like the last ones you showed with the small ball tips that you said did not work well, which is great to know.
To complete your last video see this very nice web site.
http://www.decadecounter.com/vta/tubepage.php?item=21
And so much more on this page. This site is just a treasure.
http://www.decadecounter.com/vta/tubelist.php
OK, well I got back from my musical weekend and my left hand finger tips are raw to the bone. But the weekend gave me some time to step back and think about the devices and designs etc.
I came to a very simple conclusion about the spark gap. The question to ask is what is this spark gap doing and basically we know the SG is there to create impulses in the Caduceus Coil (CC) that imparts to the output coil. Pretty simple. But then I started wondering about the HV diodes. I already blew two of them and did not want to blow my last two before I get some more and even in the HV diodes, there are many things to consider for the right choice. So I thought, let's just start from the beginning again. So no HV capacitors and no diodes. And let's put two sparks, one on each side of the CC and start from there then see by adding one or other elements into the loop to see what happens. The end game is to pulse the CC. The image below is how I set it up for now and the sparks are gong on both. I will need more time to work out settings to see if there is anything special. I think I will add a choke on one side and other ways to see if I can get that bulb to light up. I know this sounds elementary but I just had to start back from the beginning to regain some perspective. Just in case there is something very simple we have overlooked.
Back soon and thanks for a great video.
wattsup
PS: Oh yeh, the powder you were brushing off of that spark gap after 30 years in the can. I know what it is. Remember you showed one can with the spark gap inside with a nice foam material. Well that power is what remains of the foam after 30 years of storage. lol
xt_tj
Quote from: stivep on January 18, 2012, 11:41:04 PM
Wait another 40 minutes  and it should be ready :)
OK is ready
http://www.youtube.com/watch?v=Mn8TLBsR3r0&feature=youtu.be
Wesley
Congratulations !! thank you !!
please show us how to build that step by step, make a step by step video,
lets hit that oil multimillionars by the balls !
peace and love and free energy for everyone
