0 Members and 631 Guests are viewing this topic.
Khwartz
Quote from: Ghazanfar_Ali on February 02, 2012, 03:52:23 PM
@Broli
Ok here is another optimization. I simply increased the amplitude of pulsed DC from (0-5V) to (0-10V). And now I am placing a 10Ohms load which is almost equivalent to a heating element. Now The power output is around 800W.
And it did not affect the oscillation.
U can use capacitors in parallel and series combination to get the desired value.
Hi Ghaznfar_Ali! thanks for sharing :)
For increasing of power, doesn't surprise me too much: power goes with the square of the frequency but of the voltage too, when you fill caps :
P = 0,5 * C * (Vmax² - Vmin²) * fc²
with
P: power [W]
C: capacitance [F]
V: voltage [V]
fc: frequency of the charging cycles.
Do you think that is fit to your system?
Cheer.
Ghazanfar_Ali
@ All
Thanks for your comments. I know you all have some queries. First of all the schematic in which I got 800W is still under my observation coz my device sometimes gives 800 W just after powering on and connecting the load but sometimes it just stops giving output. The previous one with 42W is stable and works fine. I am attaching the schematic with bulbs connected as load.
I am out of my home station where I designed the hardware. The simulation is with me in my Laptop which I am sharing with you all. I used LRC meter to reduced the winding of my ferrite core which was already 500uH. I haven't used an air core yet as its difficult to get this value for an air core.
I will start a new thread soon with the devices pics.
stivep
QuoteCosmo LV
Dear friend
Let's assume that you  100% right
Lets assume that you are aggressive not me
Lets assume that  I  and you we both do not know  TK secret
What different does it make that you will shut at me more?
NONE....
You will be at your home and I will be at mine.
One thing I do not understand about you....
What is that you want to  prove?
Where is  you want to go with all of this?
Do you know the secret and others not// if yes say it or say that you do not want to say it.
At the end it would be not important after all.
Nobody will remember  names of that great army of voluntaries
Wesley
PS:  just say what is right approach... enlight people that's all..
nightwind
Quote from: cosmoLV on February 03, 2012, 04:43:26 PM
There are no much in his lab, Capacitors old TVs without HV transformers, and other old soviet parts and etc... But this are some 4, 5 years ago.
what has Tariel say at that time was that device is very simple.
..and at that time â€" in 2003 when Green box was filmed in his lab are no ossciloscopes (only old soviel frequency reader) thats all...
Thanks, that is what I thought.  This device doesn't require oscilloscopes or high end instruments to adjust or tune, because he didn't have any.   I do agree with you, it does require a minimum of three coils to operate and his wiring methods look poorly or hurriedly done (compared to Smith).
cosmoLV
Quote from: nightwind on February 03, 2012, 05:39:44 PM
Yes, there is nothing from Simith device. All thing is to control current and support it.Remember 220volts goes in and 220 volts goes out â€" why is that (important question) there is no inversion from DC to AC â€" AC in AC out
inverter are used only where it start device from batteries, only to support right AC current.
(actually it is always inverter) because it don't have a physical Ground â€" this is important
Keep your chakras opened :)
