0 Members and 104 Guests are viewing this topic.
hartiberlin
Quote from: AbbaRue on February 13, 2012, 06:56:13 PM
@Stefan
About the 220V 50Hz input.
If someone wants a quick easy way to get exactly 50 Hz and be in phase with the grid,
this would be the easiest way to do so, without building complex oscillator circuit.
Just use the 50 Hz grid signal as the circuits oscillator.
I was thinking of doing the same thing if I wanted the grid frequency.
But it is not connected to the grid,
the 50 Hz must be generated in this lightblue colored inverter box.
I think he is using in his round box a chopper circuit with a few Khz to interupt the 50 Hz signal
and then puts this chopped 50 Hz signal onto one coil there in his Tesla coil.
Then the BackEMF spikes from this chopping are so high in voltage, that it jumps
the sparkgap and this induces high current pulses into the 5 turn big copper winding.
( or maybe it is also an iron winding or a copper tube with iron wire inside it.
Well, if it is only a big copper wire this 5 turn winding will induce in the 4rd coil on the
Kapanadze coil again some high voltage and this is then also modulated with the 50 Hz
frequency and used as the output.
Somehow the sparkgap firing the 5 turn winding is probably making a huge magnetic field spike dB/dt inside the Kapanadze coil
and thus having a NRM transmutation of the ferrite iron isotopes from the core or any other iron wire inside the
Kapanadze coil.
Otherwise the COP=86 factor is logically not explainable.
So we need to find the circuit diagramm of this Russian made  lightblue colored inverter to dig deeper into this.
Regards, Stefan.
hartiberlin
here is still a better picture which shows the 220 Volts wires going into the round box.
cosmoLV
Quote from: xenomorphlabs on February 13, 2012, 02:52:57 AM
Well it is kind of funny if someone tells you something is not needed, yet in nearly every presentation there is
significant time being spent on focusing the camera exactly on that aspect which supposedly is not needed at all.
He DOES however say it. Up to everybody what to make out of it .... ;)
In the skype conversation TK clearly uses the term земля which means ground. Wesley might have pronounced it slightly more sounding like "grant",
but what counts is what TK said.
i Just make a correction :)
Ground is (-) it is not used to pump electricity! (potential of (-))
...in 3-phase system and in complex, you can make a Virtual Ground.
(i talked with tariel several times about this through skype) â€" if somebody need improvement of my words!
Tariel also pointed that technology of Hutchinson device and technology is the same as him device, but Tariel was changed something accidentally and get self feeding electric system instead of anty-gravity... (this are Words of Tariel)
And they who think that they want to help for the world, they are flying in sky, flying in dreams...!
Be realistic and think why nobody wants to reveal it now? Starting from me, Tariel, Hutchinson and others?
If you have this technology, you can be a super terrorist, this is something like power of God.
Who are not ready â€" it will make a bad things... (The free energy is only smart part of this device)
Time will come when it be needed. Not now â€" and i promise to everyone, you connot crack this thing so easy as you think. Not now! Maybe 5 - 8 Months and even after 2012
You can cry about children's in Africa, but who is responsible for they? united States come there and destroy whole Africans ecosystem, starting from slavery...
Humans are responsible for that what we have, and nobody save the world - we do it together by thinking and doing things right...!
Take responsibility what you think, what you do and teach each others. But the problem is, that nobody like that somebody teach him! We think that we know everything - this is the biggest problem.
Keep your chakras opened :)
energia9
Quote from: cosmoLV on February 13, 2012, 08:17:19 PM
i agree.
cosmoLV
Quote from: hartiberlin on February 13, 2012, 08:08:09 PM
Maybe helps:
Also 220v goes to coil!
