0 Members and 40 Guests are viewing this topic.
ronotte
@wattsup,
Hi, I suppose that now you should consider to have almost all the answers but of course its necessary to draw a complete & detailed data sheet/building sheet containing every possible mechanical & electrical known specs in order to not leave interrogative points. I think that we all could examine that writeup and discuss eventual variations. Certainly we are faced with to 2 main possible alternatives: 1 - build a unit like the one WNYg has, 2 - build a slightly modified unit more optimized for our intended use ( isolation degree, wires sections, number of HV turns, increase of HV coil fraction, etc).
About mechanical dimensioning, I have saved the attached 2 pics, perhaps you already have them...
Roberto
a.king21
verpies
Quote from: forest on March 14, 2012, 03:39:50 AM
Question : Is it possible to keep unloaded resonant circuit with circulating 25 amps at 200-400V with just a 100W input ??? :-\ ??? :o ::) :P :D ;) ;D :-*
Yes. Even less than that if the inductor's resistance and capacitor's ESR is kept low.
verpies
Quote from: quantumtangles on March 15, 2012, 12:23:18 AM
Bang a couple of Tesla coils together, make some sparks and pass the hat around. Ghastly.
Yup. specatacular hissing and sparking means nothing without decent In/Out power measurements or a long term self-runner.
John M
Quote from: bolt on March 14, 2012, 02:18:51 PM
YES very easy the problem is extracting the VARS to WATTS without changing the phase angle.  For the last FIVE years i have spoken about VARS and reactive power systems is the road to OU but only the last months the populous is coming to terms with the technology.
A 3 phase 5hp motor can be RV'd and run on just 15 watts!  It will have couple hundred volts and >20 amps circulating :)
By using loose magnetic coupling of several stages greater source to load isolation can be provided to limit the phase shift.
The simplest way is to use your RV'd motor, is to drive a conventional generator to produce the watts.
John
