0 Members and 119 Guests are viewing this topic.
Bruce_TPU
Quote from: Osiakosia on March 17, 2012, 02:24:46 PM
In oiginal TBC110 HV coils was used " Универсаль " wiring . ( In english I found Ing-Jang or Nets wiring ) . This
tipe of winding gets bigest inductance and lowest capasitance at the same lenght of wire . But I dont know does anybody
will made this type of wiring
Another way  if it is necessary to have capacitive connection between L12 and L13( Like T-1000 showed on diagram )  I doubt
that this method is good for us .
http://www.youtube.com/watch?v=FIOocMoRsYQ&feature=rec-fresh+div-r-8-HM
Please look how it are making .
The type of winding you are looking for appears to be a "Brooks Coil".  The one in purple.  Highest induction coil because of the geometry.
Cheers,
Bruce
jbignes5
Sooo no one has tried the mag amp yet? You'd be surprised how well it works.
http://www.themeasuringsystemofthegods.com/magnetic%20amplifiers.pdf
No problems with silicon limitations to current other then the wire gauge.
There is a very interesting circuit on page 18
Here is the other side of non linear amps:
http://www.capturedlightning.org/hot-streamer/pool/dielectric.htm
captainkt
@jbigness, I think the reason no one bothers with mag amp is there is no amplification, it simply uses a small voltage to control a large voltage up to the max input but no more.
Keith
frantz
Hi captainkt and Jbignes5,
I think captainkt have a right.
Its working "like" a transistor - similar on AC current.
Amplification of energy (OU) is not available on there.
Maybe we are blind men. Clarify this for us.
Frantz
