0 Members and 73 Guests are viewing this topic.
Acca
 This is the latest one hour video from  ThaneCHeins who has been working on shorting coils and accelerating motors AC and DC.. Everyone should see this clip..
http://www.youtube.com/watch?v=J9w8toxQl0s&list=UUnVHgFDtOaEkUJ6OJjmf1MA&feature=plcp
Al..  [/font]aka “Acca”
jbignes5
With the advent of bifilar coils do you see a way to harness disruptive discharges? This links directly to Tesla's method to modulate the electric field via disruptive discharges. But if we could make the device to get the disruptive discharge the mag amp then what do you think will happen. We could modulate and use positive feedback to maintain the modulation all from one discharge through the mag amp(oil filled).
My thoughts on bifilar coils is this. From what Tesla said there is very little self induction to them. They really have no resistance other then the wire itself. Nothing but true resistance. The resistance that heat comes from. But 90 degrees from the bifilar coil is a huge magnetic movement. If we put a heavy copper wire coil around the same core as this bifilar coil it will transform the electrical and magnetic potentials into real current. But the speed of this movement is heavily enhanced. It's like harnessing then accelerating a bullet in that sense. The target coil is traditional and recieves the energy flowing through it channeling it into our devices.
We might even be able to place these on a ring alternating emitter bifilar coil with thick pickup coils all in parallel mode to increase the current generated or even swap them in and out as needed for variable output mode.
So what we have here is a channel that we can use to shoot trough the current coil in a circular method.
Hmm so that possibilities are endless...
Kaduci
Hi Kator01
For properly understanding principles of paramagnetic-resonance you should read this book.  Tha Authors are L.I.Mandeshtam and N.D.Papaleksi. This great researh have been done in the begining of last century and was printed in 1934 in Journal of Technical Physics. The book is "On paramagnetic excitation of electrical oscillations". The original is on Russian but i think you can find it on German and English.
МандельшÑ,ам, Папалекси: О парамеÑ,рическом возбуждении элекÑ,рическиÑ... колебаний - 1934
Regards !!
T-1000
Quote from: Kaduci on March 22, 2012, 03:42:09 PM
Regards !!
Спасибо за книгу :)
The regenerative principles are widely used in this book and may be usefull for those who want to use BEMF as power source (use of echo not direct impulse you feed into coil!)
jbignes5
Quote from: T-1000 on March 22, 2012, 04:35:49 PM
Спасибо за книгу :)
I would like to get your input on the idea I had with the ring core and bifilar (gun) coil with the regular heavy current coil (target)?
I know you have some experience with this area. I'm gonna try an experiment with my core setup. I'll try to get a picture of the core for you. It is solid iron bar about 1 inch in diameter bent with a outer full radius of 10". I had it bent into two halves. If I fired a pulse into a high gauge bifilar coil, say 20-22 gauge and then wrapped some heavy house wiring about 12 gauge as the target coil what kind of response do you think I would get?
