0 Members and 424 Guests are viewing this topic.
T-1000
Quote from: jbignes5 on March 22, 2012, 05:48:06 PM
I would like to get your input on the idea I had with the ring core and bifilar (gun) coil with the regular heavy current coil (target)?
I know you have some experience with this area. I'm gonna try an experiment with my core setup. I'll try to get a picture of the core for you. It is solid iron bar about 1 inch in diameter bent with a outer full radius of 10". I had it bent into two halves. If I fired a pulse into a high gauge bifilar coil, say 20-22 gauge and then wrapped some heavy house wiring about 12 gauge as the target coil what kind of response do you think I would get?
Unless the low gauge coil is 90 degrees to high gauge coil and standing wave is in effect, the Lenz law would be instant. You could also try that on reverse then charge HV cap then discharge cap over SG to step down coil. In that way it would be different story... :)
jbignes5
Quote from: T-1000 on March 22, 2012, 05:53:01 PM
I'm gonna test the mag amp and see what kind of wave forms I can get. If I can get the same sharp effect that a spark gap can get then we won't have to worry about the SG. I'm hoping we can clean up the initial blast emf and produce clean frequency response from the heavy current coil. I'm wondering what would happen if I shorted the high current coil while the blast through the bifilar coil is happening. This should do two things. One is excite the heavy current coil and maybe even reflect the opposite way back through the bifilar coil. This seems like an interesting experiment. You guys did the same thing didn't you with the yoke coil? Well without the bifilar coil.
T-1000
Quote from: jbignes5 on March 22, 2012, 06:11:14 PM
With yoke coil it was different approach. We resonated ferrite core in 3D for nuclear magnetic resonance. Then weird things happened, including ones what cause headache for few days (probably from ultrafafast mechanical ultrasound in gap betwen 2 yoke parts). Normally you need kilowatts to cause NMR but our approach was resonance with small input - in same way as N. Tesla did.. :)
jbignes5
Quote from: T-1000 on March 22, 2012, 06:18:26 PM
Ahhh ok.. My approach would be like a drum with the two strings and beads. like this: [size=78%]http://www.janm.org/exhibits/bigdrum/resources/kids_activity1.php[/size]
The beads being the emf kinda. When rotated in between the hand this thing gets pretty fast. The drum part will be the heavy current coil and the strings and beads are the emf bursts.
I'm getting all kinds of ideas now.. What if there are two heavy current coils on opposite sides. Then we could have two drums to pull from.
Kator01
Quote from: Kaduci on March 22, 2012, 03:42:09 PM
Hi Kator01
For properly understanding principles of paramagnetic-resonance you should read this book.  Tha Authors are L.I.Mandeshtam and N.D.Papaleksi. This great researh have been done in the begining of last century and was printed in 1934 in Journal of Technical Physics. The book is "On paramagnetic excitation of electrical oscillations". The original is on Russian but i think you can find it on German and English.
МандельшÑ,ам, Папалекси: О парамеÑ,рическом возбуждении элекÑ,рическиÑ... колебаний - 1934
Regards !!
Hi Kaduci, thank you very much. I scanned my data and found it in one of my folders , it is in russian language and at the end there is a german abstract. I archived it in 2010. I can not find it in english or in german language. It was published in a german technical newpaper 1934. I doubt there exists a full translation. So if the time is right I will find someone who can translate this important piece of knowledge. It is my perception that these two gentlemen have been the only ones who have studied and published this techniques.
Kator01
