0 Members and 91 Guests are viewing this topic.
jbignes5
 I agree sparks. Curved surfaces are the way to go. It changes the actual discharge. Both in physical and electrical components.
But that other stuff was originally posted by me in another thread. The circuit is not any motor that I have seen. Well it is but you'll never guess where... Gray maybe? The plasma tube looks just like Grays attempt to make it his own.
Well I guess the question is, is TK using tubes to get a cleaner output of pulses? I know one thing he did try it and it did work. Not as strong but it did work. Look at all the video's and you will see a progression of ideas going from weak to very strong. The Turkey video was only an "This is what it can do" phase. All of the different types of loads were present, including a very industrial 3 phase motor. They were loads and not a generator or anything like that. They have to prove this can be used for industrial applications. They will be the biggest buyer of the full setup. The smaller ones will only be taps for personal or home use.
But of course if it is only a deception then it is what it is. But from what I am seeing this is no deception. As far as anyone else, it does look like some flimflam is going on. If it is indeed as good as it looks then in order to protect the idea they are gonna keep it wrapped up tight. Deceptive tatics might only be used to keep this under wraps. Who knows at this point.
Zeitmaschine
Just an idea, but maybe we should take a deeper look into this subject:
Tesla's nonlinear oscillator-shuttle-circuit
http://www.overunity.com/8288/what-im-learning-today-osc/
http://www.cheniere.org/references/TeslaOSC.pdf
If someone can find higher resolution of the illustrations, it would much appreciated.  :P
sparks
    Tesla distributed impedance drop in his transformers.  Not just voltage drop impedance drop.  When we put voltage across a resistor the voltage drop distributes uniformly across the resistor or semiconductor substrate.  The input energy goes radiant and we lose the input due to heat.  Same thing in a piece of wire until it is coiled.  Here due to selfinduction of the coil,  impedance (the product of inductance and resistance) allows no current to flow through the pulsed coil.  Where does the input pulse energy go?  Does it disappear.  The voltage drop normally associated with resistive heating of the conductor due to current flow is not present because there is no current flow past the coil.  There is however voltage drop.  The voltage is distributed in the capacitor/coil.  The magnetic field produced due to self-induction and the voltage drop due to resistance is retained in the capacitor/coil.  Successive pulses delivered to the capacitor/coil add to the energy density in the capacitor/coil.   Tesla would charge his secondaries a coil of high-selfinduction to millions of volts between terminals of the secondaries and capacity limited only by the mass of the secondary.  These collosal capacitors are capable of tetrawatt discharges.  Tesla in his patent applications alludes to the fact that a sudden discharge of his magnifying transmitter would make any chemical burning event aka tons of tnt look like a mosquito glow.  He still persisted in building one near New York City.  The people who were funding Tesla withdrew funding as soon as they found out about the inherent dangers involved.  I personally wouldn't want to be sitting near a capacitor with 10 to the god only knows farads when it decides to short.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
T-1000
Quote from: sparks on July 06, 2012, 11:30:21 AM
You might be interested in replicating this:
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out/new/topicseen/#new
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out/dlattach/attach/112576/image//
This is the right approach to increase impedance when load is applied to transformer and opposite to conventional impedance decrease under load..
To understand what is resonance capable of - http://www.youtube.com/watch?v=3YmQv6UtPPw Direct short circuit does not heat capacitor leads at all while under resonance it glow all red...
Zeitmaschine
The Secret of Electrical Free Energy, (C) 1982 T. E. Bearden
http://www.cheniere.org/books/newteslaem/p12.htm
Thirty years have passed since publication (which sounds like a description of TK device) and although I'm in no hurry an inner voice tells me it's now time to get finally a grip on this.
