0 Members and 671 Guests are viewing this topic.
Jack Noskills
I believe I discovered the same thing that TK had. So lets play with the idea for a while, in TK's hut for a lab back in 2004 somewhere in Huntsville Georgia:
He sees it working at grid frequency but he has no knowledge of EE to make a suitable driver himself. What is the option ? Hmm, induction heater, so he trashes one to get a driver. Now there is high frequency AC coming in and power is increased substantially, still it does not self run. He tries to add coils that are shorted, he discovers di-electric field perhaps and taps into that. First a coil to collect it, then into output coil in correct place that provides kicks to source. As two coil combo is just shorted energy flows without delay and kickback always occurs in correct time instant, source pushes more. Now the system eventually heats up and melts because of overload due to kick back that is not controlled. What to do ? Simplest way is to add spark plug which dumps excess to ground. Now he has a working device and its showtime! It does not matter if there is ozone or radiation due to sparks.
Basic principle works well at 50 Hz, what you need to do is to investigate if it works also at higher frequency where the power is.
When you succeed this has to go underground until enough replications. If you don't succeed then it would be nice if you explain what you did in the thread then it is case closed, if all is done correctly, as I think it should be done.
Note that when you take pictures/videos with cell phone, those files have location information embedded into them, cell phones GPS. If you release a video showing a multikilowatt device taken with cell phone, you are asking for trouble. And that is what you most likely will get, so beware.
This thread should have enough brain power to crack this, so I ask all competent experimenters to take a look at the thread with a ridiculously long name:
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out
There is information at page 13 what should be done next. It is simple build-a-little test-a-little procedure. You don't proceed to next step until previous step is completed correctly. Same way I write software, the sooner you catch the bug the better.
I cannot do this alone.
Thank you.
stivep
Quote from: a.king21 on August 10, 2012, 03:35:34 AM
Of all the contributors to this forum you were one of the few to figure out what we knew - that the visible side is all smoke and mirrors.
However, everyone makes mistakes. Identifying the components is still a usefull exercise and may lead to something.
T K was looking into FE from a young age with three childhood friends. The three became physicists, he became an architect.
The three physicists are now dead. Maybe now you will understand Wesley's cryptic message about a fairy story. TK was also looking into anti - gravity.
TK first discovered the Free Energy effect in 1996 and powered a 1kw load for three months before the device gave out.
Fairy Tail :
Note: Country of Turkey, is the imaginary birds  country:
scientists:
suppose there was 4 ...
suppose 3 of them  a say "very much dead," and one is just dead.
suppose  hotel located at steady ground, was losing power at island presentation
suppose there was  request  by "our  hero" to find house that is  next to the  sea .(nice interior house presentation)
suppose house first rented in Turkey was rented by 3 former Turkish very high rank solders
suppose the primary   "our  herorequirement was to install HV transformer next to the house
suppose there was 2.5mil. involved. That was deposited, from  very, very , official channels.
mil may stay :) for mil-liters of "very much green water" :) :) ..............he he
The water was taken in small parts and  utilized. till year 2008
Part of that water was given to  "our  hero" , but that  "green  water" was unfortunately lost.
It made  "our  hero"  to feel   very, very independent at the first time of his life.
He did not  know how to manage this "pressures liquid." He just got wild ,  extremely wild.
That was nothing bad  he thought that  "green  water" will be more and more  available.. The  "green  water"   start about to dry, in mid of 2008.
Wesley
some  of the addition:
  http://www.realstrannik.ru/forum/39-kapanadze/69902-kapanadze-4.html?limit=18&start=1602
http://www.realstrannik.ru/forum/39-kapanadze/69902-kapanadze-4.html?limit=18&start=1656
frantz
verpies
Quote from: forest on August 09, 2012, 02:23:41 PM
You better stop, there is no gain in assuming that device is a hoax.
I am not assuming it is a hoax.  I am just considering the video evidence - just like everyone else here.
The possibility of transferring electrical energy trough the Litzed Braid with an aid of a mere HV transformer, makes this video evidence equivocal.
Also, I hope that the next "demo taker" reads this post and takes a closer look at this braid.
This is merely due diligence.
frantz
Hi all,
in my opinion, I can agree with all guys who's thinking the main part of TK device is hidden inside the closed box.
In regard to the heater....
the previous concept presented by FreeEnergyInfo had mistakes, because two frequencies summarised inside magnetic field given nothing.
In my opinion we should focus on monopolar solution.
I would like to present my concept (this is not final scheme).
This idea is based on adding (additional) magnetic field to the base magnetic field generated on by main work voltage.
On one half of 50 Hz I'm adding magnetic field in one direction from resonance heater circuit. on second half of wave 50 Hz I'm adding magnetic field in opposite direction. and again and again.
Important: capacitor parallel connected to the 220V source is necessary because I must close loop of additional current not by voltage source (inverter) only some other part. If I don't will use capacitor, I will burn inverter...
What do you think about this idea....
P.S.
What is important in this solution?
We can build this transformer on plain steel core....
even though we use high-frequency in heater circuit.... ;-)
P.S.2
What is missing in scheme?
Voltage dividers for triacs gates. and transistor for power source of heater which is necessary for current regulating (additional B field in transformer) which is negative feedback to fit power to the load....
P.S.3
Next important info. In transformer we don't have negative impact between heater coils and output coils because B field is in the same direction. This transformer don't work like grid transformer. Heater is only pump which increase B field inside output  transformer (the same current not voltage).
GUYS, COMMENT PLEASE.
I NEED HELP WITH TRIACS. SOMEBODY KNOW HOW IS RECOVERY TIME FOR POWER TRIACS?
I'M NOT ASKING ABOUT GATE PARAMETERS, because gates are working on 50Hz.
