0 Members and 51 Guests are viewing this topic.
Dom Tesla
Quote from: Zeitmaschine on August 24, 2012, 09:02:59 AM
One more guy that can't believe there are no clear results after 895 pages. :(
Can't believe it myself. Could easily be that we are all in the wrong movie.
He he, I was afraid to hear that....  Jea I just hope that movie is not "Die Unendliche Geschichte" he he
Thanks for the reply Zeitgeist...
Schönen Tag noch !!
Zeitmaschine
Speaking about phase shift in a transformer in order to get resonance, what is this guy doing here:
Wesley introduces:" part #1 transformer by Alexander Kugushov" with respect to Tariel Kapanadze
It looks like he is manipulating the core of a 50Hz transformer by means of some magnets. How could this affect the function of the transformer? Could it be that the additional magnets are slowing down the speed of the moving magnetic field in the core, so that the secondary coil goes in (magnetic) resonance with the primary coil?
Just thinking ...
And what happens here:
Simple to build isolation transformer that consumes less power than it gives out
A transformer connected to a second transformer. I'm sure that will cause a delay in the magnetic field flux between input and output. If one hits a proper delay then there could be resonance between the primary and secondary coil.
Just thinking ...
Perhaps it's time to change the movie reel: Load »The Time Machine« and go back to Colorado Springs, 1899. :)
dole
Quote from: a.king21 on August 24, 2012, 12:21:35 AM
yes - you get a short. But it's still on my "to do" list.
Yes - but noting special in the way it is ... but there is always room for improvement.
And without correct measurement someone may think differently.
So sorry for repeating, one important message to all serous electricians:
Run ALWAYS everything you do from the BATTERY as the source, and measure INPUT DC.
Setup: Two 40W bulbs, one direct to source, other through the arrangement.
d.
Shokac
Quote from: Kator01 on August 24, 2012, 11:55:00 AM
Shokac,
Question : how did you measure the existence of 23 A ?
Almost an impossibilty what you say:
The reactance of 8 pf at 50 Hz is 2.5 Megaohm !
The inductance of the secondary isdt about 3 to 4 H, Ohmic restistance is about 130 Ohm
Voltage-drop across the 8 pf condenser ( 2.5 MOhm) at 23 A = Xl * I = 57 Million Volt ??!!
Uuhps....
Power consumed in seconday at 23 A, wire of secondary is AWG 28
If a current of 23 A flows through the seconday with 130 Ohm a power of 2990 Watt is flowing through this coil. It will burn down your secondary in seconds, because peak-power is relevant in the wire not mean-power.
Think about this twice, before you make statements like this and claiming that you "try all about you talking"
Kator01
First!
induntace of secundary on MOT is cca 60H....
Try again with matematics....
p.s
Not forgeret that is secundar in resonace!
Try this:
frankidel
Quote from: wattsup on August 24, 2012, 09:14:36 AM
@all
This is how I see the base problem. (My opinions only)
Example:
You want 2200 watts to heat up your element.
Now let's say you only have 220V at 5 amps so an output of 1100 watts that is far away from any OU because your real juice going in is 1400 watts.
So your choice is two fold.
A)  Either you find a way to double the 220v amperage from 5 to 10 amps. (or 120v from 10 to 20 amps)
Orrrrrrrrrrrrrrrrrrrrrrrrr.................................
B) You raise the available low voltage of 220v/5A to 11,000v and 0.1 amps (same energy).
Then you work to raise the 0.1 amps to 0.2 amps and more.
So, which of A or B do you think is easier to accomplish?
Why does it have to be any more complicated then that and again, which method would you prefer to use to tackle the problem? A or B?
Guys have been trying A for decades and decades now with nothing to show for it. All the Romero Wheels work in A. Also trying to increase amperage but the drag gets you all the time.
Most of the greats that have either been suppressed or forgotten have been using B. So why do you think TK is any different when he is concretely showing solid results with outcome of running a heating element for 4.5 hours, with wires so thin, my speakers would choke.
Then question of fake or not........... When you build something for a reason, all the components and connections will have a logical reason that any regular EE will see right away. There is none that are bad in TK's builds. All the wires are always going somewhere logical. So if I ever found, in a TK build, aaaaaaaaaa, hmmmmmmmmmmmmmm, Wire X, it will be a pleasure to show it to all and learn from that. But no wire x yet. How many pages on this thread and no wire x.
It has to be simple.
In the Aq2v....
The triple transformer is the positive potential. Since only the positive is being consumed with its negative left in a limbo of paralleled secondaries. This one polarity usage means the drive system consumes little energy and maybe will take the amperage of the negative as well and give it to the positive side, since it is not needed. Probably those two primaries on 1 and 2 are being used to send back juice to loop the driving system. hehehe
The TK coil (TKc) is the negative potential rectifier next to ground. This whole deal relies on the TKc being able "do something" to trick the negative ground into charging the TKc, so it can be a good negative to the load. The TKc winding is creating many HV convergent lines that are 6 phased, probably causing the ground negative to see it as a much stronger overall potential then it really is, hence piling on more negative potential.
The "load adjuster" is the Coily Coil circuit. It is the only point at output that vary from load to no load since it is basically a glorified short circuit.
The load, any load is a dual potential rectifier by demand because the load itself will be permeated with the HV+ from one side and the charging negative from the other side. The load will bring down high voltage to an RMS value as depicted by the level of heat generated by the load element. This is all done in the load. TK does not see a load like we do. He uses the load as a step-down transformer. He sees the load as another spark gap using resistance instead. Or as a vacuum tube, the load is the space between the anode and cathode.
Time to go back into build mode and experiment with the above notions. I still need to find a good deal on HV wire. Might be one strand 18 awg or thinner muti-strand to total 18 awg, rated 12,000 volts. I don't think I need 25kv.
wattsup
Hi about having let say 2000 V 0.1 Amp or 200 V 1 amp.  If you use the 3 phase transformer, input 220 V X 1 amp = 220W, output 3 times 2200 V @ 0.1 Amp, do you have 660 W ??
