0 Members and 181 Guests are viewing this topic.
wattsup
@all
I am in Paris till next Monday but followed the thread via my Android mobile. Please do not get overly caught up in to many distractions. This is a pivotal time and very crucial to keep concentrated.
There is one thing that has bugged me about the blue wire that goes to the triple transformer HV positive. If someone can put up that image again since I cannot with my device, you will notice that there is not any showing on the white coating we should see with normal coax. I think I know why. I think they shorted the outer shield to the center conductor then to hide this they simply stretch the blue outer layer so it covered the.solder connection. If you look carefully you will notice that the.blue.coating is thinner where the center contuctor comes out of the blue opening when compared with the same blue but but an inch away from the end
The only thing this means is that the outer and inner lines of the coax are shorted at the HV+.
Also consider a coax with nice dense shield will provide a good source of parallel capacitance per foot lenght of coax so for around 150 feet of coax you will have enough pf value to provide both a center conductor with its own source of ressonance being at the same time the shielding. The loop should happen between the center line and the shield if at the right frequency to load.
Anyways keep up the good work and I can't wait to be back at my bench.
wattsup
jbignes5
Well like I said after thinking about this, that which we seek, Tesla hinted at the power of this method. One real quote comes to mind. "The thin copper wires exploded with the power of dynamite." This is very telling of how Tesla thought of this energy. Can we all agree that this electricity has very high voltage? Can we also agree that this form of electricity has greater ability to switch at faster speeds? If High voltage, High frequency electricity has properties like the static realm then it is entirely possible that it can gather and condense and then explosively discharge into a wire(coil) and quite possibly do more work then was required to manifest it.
We all know there are free charges everywhere there is heat and light, electric fields seem to be a way to gather and bring those charges into our systems if we design it that way. With the spark gap it is quite possible that we could form an analogy of a gun. With the gap being the bullet chamber and the wire being the barrel which is also attached to the ground or target. Now if we take the wire/barrel and coil it wouldn't that be a way to harness the force of the bullets while not disturbing it's path to ground?  Except for a slowing of the bullet after it has been fired.
In my quest to find the truth it dawned on me that this is an energizing radiation. All of the reports from Tesla's experiments backs this statement up. That is why I asked for the experiments done by a few here in this thread to be done. Energizing a capacitor to self excite and produce a useful output. It was done and proofed on this thread. Even trough many layers of the capacitor this energizing energy penetrated and excited the layers of the foil capacitor. Well that same method is used by Kapanadze. Call him what you will but he figured it out as well. All his circuit is, is a hairpin circuit wrapped around a solenoid coil. It pumps the coil with the energizing field into current stimulation for any load to use. Light bulbs being the easiest to trick with this system. Solenoid coils have a rather unique ability to polarize energy. With one end being opposite the other. If one side of the coil is 120v then the other end is 1200v. After that it will reverse when the accumulated energy gets sucked back into the solenoid after power is removed. Of course adding an iron core to that makes it have a stronger response. What if this core was circular and around the core is 4 solenoid coils in pairs? This was Tesla's original Idea. He knew copper reacted to this energizing field in a current fashion. It stimulated the copper with a real heavy current. Well Tesla though hey if it is static then it will not work as well and used his principle of generators to form the patent I'll show you here:
[size=78%]http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine[/size]
I have shown this before but I don't think people understood that this is not an ordinary Motor/Generator. I uses higher voltages for the field coils to stimulate the heavy copper coils in the rotor into real current flow. There is a bit missing from this most simplistic design but this shows that Tesla found this to be a transformer of the new voltage field he discovered into the heavy current that most already had been accustomed to. If the field coils emitted a high voltage field then this device could be turned with ease, even when under stress from a load because the rotor coils were of heavy current design. If it produced a heavy magnetic field, it would cut the field coils and be converted into high voltage again. In effect transforming the heavy magnetic field back into high voltage field which only makes the process work better.
You have to think like Tesla to understand his methods. He was a high voltage man. That was his life after discovering that new realm and it is the key to understanding his patents in a new light.
itsu
Quote from: T-1000 on September 12, 2012, 06:09:15 PM
Woopy, Itsu and a.king, this is a job for you TODO ASAP :)
Cheers!
Thanks for the encouragement T, but as i already was experimenting with coax cable coils, i already was intriged by this selfrunner.
I have a hard time understanding the Russian drawings/text etc, but slowly more info is coming in English.
My first attention is to the main coil, and i came up with the following info (all CW):
L1 = 820t 0.25mm on 4.6cm former (white/orange leads)
L2 = 315t 0.65mm on top of L1     (magnet wire leads to caps)
L3 =  41t 5.9m Coax cable        (probably NOT RG58 as to my knowledge RG58 is always black coated)
L4 =  72t                        (combination of brown and blue cable) not sure what thickness.
I started building my coil and use:
cardboard former 5cm:
L1 690t 0.4mm  3.3mH / 14.5 ohm
L2 380t 0.6mm  1.5mH /  0.5 ohm
L3  41t (6m) 75 ohm coax shorted at 1 end
L4  i will use 70t of some kind of wire i have laying around.
Questions for me presently are:
How to create this 1-5ns pulse (my FG generates a 80ns pulse at best)
What is the amplitude of this nano pulse (5v?, 500v?, 5Kv?)
What is the frequency/amplitude and pulse shape on the L1 coil (match the resonance frequency of L2 tank coil?)?
Video to be seen here:  http://www.youtube.com/watch?v=MQUciCy9p3A&feature=youtu.be
I will try to get more to the point in the video's, thus shorther, in the follow ups if any.
Next will be to make some measurements on the coil when pulsed.
Regards Itsu
Zeitmaschine
Machine translation of the Melnichenko patent (WO/2003/061110) as mentioned here on p. 336
METHOD FOR ENERGY GENERATION BY MEANS OF ELECTROMAGNETIC WAVES AND DEVICE FOR CARRYING OUT SAID METHOD (VARIANTS)
Field of technology
The claimed invention relates to energy and electrical engineering and can be used to create a stand-alone power plants or their parts, power supplies, generators and heat.
Background Art
There is a method of energy generation, which consists in the fact that the receiver delivers the energy transferred by a special transmitter (see U.S. Patent N ° 645578 Tesla on March 20, 1900). The disadvantage of this method is that generated by the receiver electromagnetic energy has a positive increment.
In addition, a process of power generation on the basis of the same unit consists in the fact that the receiver delivers the energy transferred by a special transducer (U.S. Patent N ° 649621 Tesla on May 15, 1900). The drawback of the solution is also a fact that generated by the receiver electromagnetic energy has a positive increment.
Technical result, which is aimed at achieving the claimed invention is to allow the generation of additional power to the abstracted from the primary source of energy. This technical result is achieved by the fact that the method of addition of the interference of waves on the load in the presence of electromagnetic waves guiding systems, or the method of the prior accumulation of energy of electromagnetic waves in the drive, with subsequent release of the load.
Disclosure of invention
Way of generating energy on the electromagnetic waves is a process in which the electromagnetic waves from one or more emitters in phase work in a single load, or first accumulated in the storage (Volumetric or other cavity, coaxial or waveguide line, or in the form of standing waves in the coils, wires, and other types of feeder lines), and then sent to a load. Load may serve as a reception area, transmitting antenna, resistance, straightening rektenna absorbing dielectric, such as water, etc. To generate the load adds the amplitudes of electromagnetic waves (superposition principle), and the energy of the electromagnetic field is proportional to the square of the amplitude of the total field. The energy of electromagnetic waves is a non-additive (arithmetic does not add up) quantity, so the load of the energy released is proportional to the square of the amplitude of the total, which is more than the energy of the incident electromagnetic waves each individually. The load is in-phase addition of the amplitudes of waves. The load can be used absorbent dielectric-transfer medium (eg, water), passing through the waveguide or other part of the feeder line, or straightening rektennu, resistance, or the receiving antenna (pins and hinges coaxial wave transitions, etc.), power transmission in the feeder link.
In the case of electromagnetic waves of accumulation and storage, energy storage in the same proportional to the square of the amplitude of the electric and magnetic fields, that is, (at very low loss), total square of the amplitude of the waves that are included in the drive from the generator. Electromagnetic wave energy policy non-additive, that is not summed arithmetically, so the energy in the store is growing faster than is consumed in the drive from the generator (with small losses in the drive).
Device implementing a method of generating energy on the electromagnetic waves, which is a process in which the electromagnetic waves from one or more emitters in phase work in a single load, in general, consists of one or more of electromagnetic waves with emitters, power dividers and feeder lines, in which two or more emitters of electromagnetic waves simultaneously work on a single load, and the radiators are located around the load, or radiation from different emitters concentrated on load through reflectors or lenses.
Said device features the following realization:
1.1. The device, in which the waveguide (wire, strip, coaxial and other types of feeder lines), the load is in addition of the amplitudes of two (or more) back-to-traveling electromagnetic waves that fall on both sides of the load. Load, in this case, is located between the emitters.
1.2. The device, which is implemented on the basis of the cavity in which the emitters are arranged relative to the load so that the load is in addition of the amplitudes of electromagnetic waves from transmitters and reflected electromagnetic waves, for example, the emitters are located on different sides of the load inside the cavity.
1.3. The device, which are connected to a generator or generators of electromagnetic wave emitters are a system of η-th number of narrowly focused (eg, horn) antennas operating in phase with the total load on all sides.
1.4. The device, which is implemented on the basis of the width of the waveguide in many wavelengths, in which emitters are arranged in a row across the waveguide, the concentration of electromagnetic waves at the load is achieved by a gradual narrowing of the waveguide in the load or geometric hub or hubs (mirror or mirrors, particular parabolic reflectors), or lenses that focus the electromagnetic wave to the load.
The best embodiment of the device
The best is the version of the device referred to in clause 1.2. This device operates as follows:
Electromagnetic energy passing from the generator through a power divider is fed to the radiators located inside the cavity. The load is also inside the cavity. Electromagnetic waves from transmitters and reflected from the walls of the cavity in phase interfere with the load, and the load is in addition of the amplitudes of electromagnetic waves. This device is the best location of radiators from different sides of the load.
In addition, the inventive method can be implemented using a different version of the device that implements a method of generating energy on the electromagnetic waves, which is a process in which the electromagnetic waves from one or more emitters first accumulate in the tank (or other bulk resonator, resonance coil or resonating part of the feed line, such as the length of the waveguide, coaxial, strip or wire line, etc.), and then sent to the load, in general, consists of one or more of electromagnetic waves with emitters, power dividers and feeder lines, direct drive and switch. In this case, the drive is connected to a generator of electromagnetic waves through a feeder line, or through a special agent. Load through feeder line is connected to the drive (for example, to the ends of the resonant coil) through the switch-switch. A switch can perform the switch based on transistors, ΡΙΝ-diodes, gas discharge punches, ferrite or ferroelectric gate controlled valves.
The device works in a two-phase mode. In the first phase, there is an accumulation of electromagnetic waves that are included in the cavity of the generator of electromagnetic waves, and switch-to-switch prevents the allocation of wave energy in the load. In the second phase, after the accumulation of electromagnetic waves, the switch-to-switch ceases to impede the energy of electromagnetic waves in the load, in this case, the accumulation of electromagnetic waves can be paused for a moment before resuming the switching of the first phase.
This version of the device features the following realization:
2.1. Device in which the generator through the feeder link or agent is connected to a cavity resonator, which in the feeder link (coaxial, waveguide, or wire, etc.) and a switch (based on transistors, ΡΙΝ-diodes, etc.) load is connected, the switch changes the impedance of the feed line, the load itself, or parts of it.
2.2. The device, in which the load is placed directly in the cavity, or is part of the cavity, or the load itself is a storage of electromagnetic waves, while periodically changing the resistance (impedance) of the load itself, or parts of it due to its physical properties (nonlinear resistance load), or due to external or internal control impedance.
The best is the version of the device referred to in section 2.1. This device operates as follows: Electromagnetic waves coming from the generator to the drive (resonator) that a standing electromagnetic wave whose amplitude is in the ideal case (loss) by the sum of the amplitudes of electromagnetic waves that are included in the cavity. In the first phase, there is an accumulation of electromagnetic waves that are included in the cavity of the generator of electromagnetic waves, and switch-to-switch prevents the allocation of wave energy in the load. In the second phase, after the accumulation of electromagnetic waves, the switch-commutators ceases to impede the energy of electromagnetic waves in the load, in this case, the accumulation of electromagnetic waves can be paused for a moment before resuming the switching of the first phase.
Industrial Applicability
Way of generating energy on the electromagnetic waves and the device for its implementation can be implemented based on the existing technology of microwave and UHF (magnetrons, klystrons, amlitrony, waveguides, feeders, etc.).
frantz
Quote from: jbignes5 on September 14, 2012, 09:32:51 AM
Great description jbibnes5,  8)
I feel it but don't see yet.
In my understanding we should use:
1. HV on stator coils with good insulator
2. we can recalculate coils with large number of turns - we will have large amount of Magnetic field (from many turns) and electrostatic field (from HV power supply)
Ok what about frequency (50 to 400Hz) it will be correct? And on there should be AC current or pulsed DC?
could you draw some picture?
frantz
