0 Members and 189 Guests are viewing this topic.
Zeitmaschine
Quote from: jbignes5 on May 05, 2012, 09:13:06 AM
When dealing with a new form of electrical energy, you need to find out it's abilities. I think I have seen videos of the hair pin and the energy is very strange. Only the target filament is targeted and will bypass everything even dropping it in water. The next experiment is that he reached into the water and picked up the bulb and played with the bulb under the water with no harm of sensation.
Is it this one? Bulb in water :)
Page 339: THE INVENTIONS RESEARCHES AND WRITINGS OF NIKOLA TESLA
Seems this hairpin setup is not even patented so there is no use looking in patents for it. But anyway there is a striking resemblance of the Tesla patent 514,168 as I have mentioned a short while ago. Instead of a stout copper bar and connected lamps the output goes here to a second transformer (in oil).
Hence something to ponder: Could the orange cable in the 2004 setup be connected to a stout wire (copper bar) within the tin can? Where is the stout copper bar in the other Kapanadze devices? ???
Sorry if I'm asking stupid things ... ::)
jbignes5
Quote from: Zeitmaschine on October 23, 2012, 10:20:27 AM
The stout copper bar is the one with the spark gap built in. It was right in front of your eyes the whole time.
The load coil is inside of this bar. So induction and the angles of that bar focuses the field.
I'll see if I can draw it up.
It maybe a little confusing but the filed lines are normally balanced meaning given the open field they would be the same. But adding the compression increases the intensity of the field. Lets just say that a wire has a certain field in normal space. Once it is changed that field doesn't change but in intensity if the field gets compressed. The compression is based off of the same connection to a pressure and morphs from the original uncoiled or compressed state.
My drawing is a one sided view as if you were looking down the coil.
Look at the hair pin and you will see this compression because it is not a straight run but a half of a turn in a coil. This proved that he was running from a difference in potential from that bend. Yes it is a version of displacement current because the matter is stimulated to provide the current back and forth. If the stimulation wasn't present no action would be seen. Unless you provided the perfect capacitor to use as the pumps.
And hey yes I'm not perfect. I am only going by what I was taught and by my own intuition in my researching. Math is good for estimating the known values but if you don't have the entire picture included then just what are you estimating? This is why things are accepted in one branch but rejected in another because problems arise and fudge the whole mess up. So instead of looking at where the problem is they invent math that exactly replicates the effects and then says oh don't pay attention to the other things because it doesn't matter. But it does, it matters a lot because it shows how we got to the places we are at. Not knowing is ignorance and not looking is completely unwise. We have enough knowledge now to start connecting the dots of the smallest forms of matter and yet we still marvel at what we are seeing because it still doesn't make sense with our established laws.
Someone mention the sun and gave the explanation that is is a fusion reactor?? What how do you explain the cold surface below the corona-sphere. Those black spots are not from anything other then it is a electrode. All of the links I provided show that the sun is a very solid super structure with anode like discharge surrounding the whole anode. The mass alone could explain this. The electric universe is a great series to look at and is also jiving at what we are seeing.
Getting back to the picture below if you dropped a charge to the right of the words Same Value which direction would it flow? Is there a chance that the bifilar coil would intercept that flow? No matter what polarity of the charge is? Bifilar is both polarities filtered or redirected into a unified flow. Both polarities are used to attract each other slingshot past then back again a second time. This is a charge receiver and accelerator. Plain and simple.
Zeitmaschine
Quote from: jbignes5 on October 23, 2012, 10:30:42 AM
Quote from: TheBuzz on October 23, 2012, 10:50:41 AM
Got stout?
Not enough stout. Where can I see a stout copper bar in series with a spark gap in the Tesla drawings? The spark gap is here connected to the high voltage secondary coil (thin wire) of a transformer.
Furthermore the spark gap in series with the stout coil does not even work all the time in the 2004 video as it is supposed to do. Besides how does it come that the TK device outputs a 50Hz current but not pure high frequency? So something is still wrong here.
And through which center (or bottom winding) runs a stout copper or aluminum tube? ??? ???
andrea76
starcruiser
@wings, nice that someone is trying to re-patent a Tesla invention huh? I read the patent (first link provided) that relies on a Tesla coil for driving the extra coils placed around the SEMR (Tesla Coil) which Tesla spoke of in his notes and patents.
He might as well try and patent transformers and induction action too
Regards,
Carl
