0 Members and 74 Guests are viewing this topic.
Farmhand
Quote from: Zeitmaschine on November 02, 2012, 01:56:08 PM
100 square kilometer (10 ×10 kilometer) equals a circle with a radius of 5.642 kilometer. A sphere with a radius of 5.642 kilometer has a surface area of 400 square kilometer. Thus if the receiver is 5.642 kilometer away from the transmitter then the initial energy is spread not on 100 square kilometer but on 400 square kilometer. So according to this calculation method it is even 4 times more Over Unity.
Circle And Sphere Area Calculator
Then why are we still here? Maybe I should start making experiments again ...
Hi Zeitmaschine, My Crystal radio works from ground currents in my opinion, I don't have an antenna as such just a small Tesla coil.
If I scope the ground I can see the ground waves, lots of them 50 Hz and other frequencies as well including the 840 kHz of the radio stations 10 kW transmitter
about 20 klm away. So by connecting the Tesla coil secondary to ground (tuned to about 840 kHz) and tuning the primary capacitance I can pick up the station quite well.
The Tesla coil just sits on the table (no antenna strung up).  Any ground wave can be tapped in the same way.
I used an amplifier so I can use a speaker but it works with just the earpiece.
My point is all the energy from the transmitter is not sent out through the air, only some. The 10 kW transmitter probably uses 15 kW and if a tuned receiver was ground
connected and placed reasonably close to the transmitter when a significant load was drawn from the receiver the transmitter would increase input or the transmitter power
would be drawn down. This would happen because the energy from the transmitter would be tapped from the ground. (See Tesla quote below) Which describes how a crystal
radio works and also how a large receiver station works.
Crystal Radio
http://www.youtube.com/watch?v=_8OjkE0274Y
QuoteCounsel
To illustrate my question, take for instance the energy used at Sayville and the reception of that at Nauen.  I want to know whether it is your idea that the reception there is due to the earth currents that you have described or to the radiated energy.
Tesla
It is far more due to the earth currents than to the radiated energy.  I believe, indeed, that the radiated energy alone could not possibly produce the effect across the Atlantic.  It is simply because they are incidentally sending a current through the globe -- which they think is their current -- that the receiver is affected.  The current produces variations of potential at the earth's surface in Germany; these fluctuations of potential energize the circuit, and by resonance they increase the potential there and operate the receiver.  But I do not mean that it is absolutely impossible to use my apparatus and operate with electromagnetic waves across the Atlantic or Pacific.  I only say that according to calculations, for instance, which I have made of the Sayville plant, the radiated energy is very small and cannot be operative.  I have also calculated the distribution of the charge on the antenna.  I am told that the Sayville antenna is without abrupt changes of capacity.  It is impossible.  There are changes even in a cylindrical antenna; but particularly in that form at Sayville -- there are very abrupt changes
Cheers
P.S. My crystal radio is not working from energy collected by an antenna, it is working by the ground waves/currents and the resonance of the receiver increases the potential.
frankidel
Quote from: verpies on November 02, 2012, 08:06:55 PM
Most of us can't read the french forum because we do not know the french language.
Is that document from Сергей related to this french guy?
Whoever drew/wrote it, most certainly has skill in electronics.
Hi dont know if it's from fabrice andré, but the commentaries are quite good, gonna read it all the way, there is a translation of a document from utkin i think.
tagor
Quote from: frankidel on November 02, 2012, 11:28:03 PM
now i am very sure it is not from FA , FA is only for communication
i am investigating to contact the real inventor , this guy has real electronics skill
i think the device is real ... but who knows !!
FA  has a black side and the other face quite nice
FreeEnergyInfo
